Gold Member Username: Mixneffect
Orangevale,
Ca.
Post Number: 1061 Registered: Apr-05
Posted on Wiring options have no effect on the speaker since it is done prior to the crossover. DO NOT CHANGE WIRING CONFIGURATION PAST THE CROSSOVER ! It will change the crossover point, and sound terrible. The only setback to wiring components other than straight, is that you will get mono. |
