Buget 500 dollars
Username: Caraudio
Toronto, Ontario Canada
Post Number: 410
Now if id move from my Lanzars and have a buget of 500 dollars for amp and sub what could you get for me im looking for 1 12" sub and an AMP. 500 Canadian give me links.
Username: Loc_out
Santa Ana, Ca
Post Number: 426
Try looking at ebay. You might want to save a lil bit more money remember you get what you pay for.
Username: John_wash
Nashville, Tennessee
Post Number: 322
Spl, Sq, or Sql?
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1124
also how much is 500 canadian in american money???
Username: Killer44
Ontario Canada
Post Number: 540
get 1 Kicker compvx
http://cgi.ebay.ca/KICKER-CVX12-2-COMPVX-L7-12-1500w-CAR-AUDIO-SUBWOOFER_W0QQite mZ8077149487QQihZ019QQcategoryZ38647QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Wire it to 4 ohms
and a audiobahn a8002v (800rms @ 4ohms)
http://cgi.ebay.ca/A8002V-Audiobahn-800W-RMS-2-1-Ch-Intake-Amp-NEW-A8002T_W0QQit emZ9742407856QQihZ008QQcategoryZ48597QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Caraudio
Post Number: 411
^ That looks to be a very good deal in place would you guys reccomend i look into that deal? I can get a Kicker Comp for 100 Canadian tho.
So would you guys agree in this system
Oh and killer nuff respect for the finds:-)
Username: Caraudio
Post Number: 412
500 Canadian is about 450 American.
Username: Killer44
Ontario Canada
Post Number: 546
a kicker comp is a much lower model then the compvx...the comp is a good sub but will get nowhere as loud as the compvx...i know around here the compvx is like 500candian...the comp's are about 100 like u said...
Username: Caraudio
Post Number: 413
That 1 kicker compvx is a really good buy then but hte box looks beat up.
Username: Caraudio
Post Number: 414
Also isnt AUdiobahn the Bad in the good the bad the ugly list?
Username: Caraudio
Post Number: 417
How would i wire that sub to 4ohms its a 2ohm dual voice coil sub? Is it possible to bridge it ?
Username: _jay_
Post Number: 161
how much louder is the cvrvx then the L7?? any1 have hands on experience?
Username: Caraudio
Post Number: 418
Ive seen alot of CVX threads how loud can this bad boy get in terms of DB with that setup??
Username: Caraudio
Post Number: 419
Id want it to be loud and sound good.
Username: Sw9152
Michigan
Post Number: 802
15" AA arsenal $250 http://ascendantaudio.com/
audiobahn a8000t $150 www.ebay.com
Username: Terry6405
Sullivan, IN US
Post Number: 841
im not a fan of audiobaun, but i have herd that model puts out what it claims so who cares, just try to get a warranty and that wont be a problem at all. and DBs are hard to tell, but ill bet you can get close to 140 in a car with that if you tuned it a little high, like 35-38hz, but that is a guess
Username: Sw9152
Michigan
Post Number: 809
140 is a little high but they do get loud.
Username: Caraudio
Post Number: 425
Well what about a P3? I could grab one P3 for 250.
Username: Caraudio
Post Number: 426
so the CVX or the P3? Also i can get the P3 Punch for 250 but I dont really want to spend to much money on a system so. I dont know.
Username: Sw9152
Michigan
Post Number: 820
dont get the P3
Username: Dannyboyy
Peterborough, NH USA
Post Number: 115
12" sound splinter rlp12 $250
Username: Caraudio
Post Number: 430
Would you guys agree the CVX and Audiobhan for a decent system nothing to hit 150DB or nothing just a good system for under 400 is a good bid? Also having Kicker at the top of the good bad ugly reccomended chart its lot better from Lanzar and some one told me that this sytsem will only be a bit better then my lanzar system:|!????
Username: Caraudio
Post Number: 431
www.edesignaudio.com
this site was reccomended to me and i was told it has some of the best stuff out there. "Top Notch"
Username: Sw9152
Michigan
Post Number: 836
the abahn amp and cvx would be a great budget setup.
Username: Caraudio
Post Number: 435
budget setup as in it will be decent? Tell me it will be an above average bid and what if i was to get one probably amp from eddesign but is that company really that good?
Post Number: 1145
audiobahn subs are unreliable and sound horrible..but thier amps are good for the price..i mean 120 for 800 watts u cant beat tht???
but the edamps are a bit more expensive....and it all depends on the VC config of the su ur gettin.......u gettin the dual 2 or dual 4?
Username: Sw9152
Michigan
Post Number: 842
no it will be a loud with decent sound quality setup for a relatively small amout of money. a watt is a watt, the audiobahn will push 800wrms the only better amp ED has is the nine.1 and that is $350 compared to the abahn $150. i would get the a8000t.
Username: Caraudio
Post Number: 441
DUAL 2ohm CVX.
Username: Caraudio
Post Number: 442
If wired at 4ohms that Audiobahn amp puts out 800wrms so i guess that works great but is that 2ohm CVX a good sub? Better theN Lanzars and X2 X4 times betteR?
Username: Sw9152
Michigan
Post Number: 845
no, the a8000t wired at 2 ohms puts out 800wrms. you would need the dual 4 cvx.
Username: Caraudio
Post Number: 443
audiobahn a8002v is the amp im looking to get. At 4ohms it puts out 800RMS.
Unless theres a better price out there for the amp your talking about and the difference is?
Is there a way to wire a 2ohm dvc sub to 4ohms?
Username: Caraudio
Post Number: 444
I mean at 4ohms it puts out 800RMS but im talking if i wire the sub to 4ohms.
