New member Username: CallmeqPost Number: 1 Registered: Nov-06 | i am very new at this please help. I just bought a 37 magnavox lcd hdtv and the picture looks like i am looking through a childs prisim. have tried all settings they all look the same. do you have to have hd cable or satalite for the picture to on any channel to look right? hope u can help and thanks (bought the tv without knowing anything about hdtv how it works and had no saleman explain thought i was just buying a nice tv) |
Bronze Member Username: Robin_hudPost Number: 54 Registered: Sep-06 | Susan, Buy any type of inside/outside HDTV antenna, connect it to your TV - air antenna output, scan TV and compare HDTV picture and regular cable. This is best way to start, learn, set up and see differences |
Bronze Member Username: MvanmeterKY USA Post Number: 73 Registered: Jan-06 | Susan, please post just your ZIP code and we can check www.antennaweb.org and see what is available in your area. Then we can recommend what form of antenna you will need to view your local broadcasters digital TV signal. |
