Jtag Cable
Username: Gunaa
Post Number: 64
Hi LK and others!!
The jtag cable need AC power or the printer port supply the power? I'm going to jtag my pansat 2500a clone. and also do I need DB9 cable at the same time?
Username: Johnny67
Post Number: 18
The printer port supplies the power, you need to make sure you have the bl updater, the new bin and follow the instructions exact, so read over and over if you have to, once the jtag is complete, you will need the db9 to reload your computer with the software, make sure the jtag is off when you start the db9 process, I just revived my fortec which had no power no lights nothing, I just followed the process, good luck!
Username: Gunaa
Post Number: 65
Thanks joseph salinas!!!
Username: Gunaa
Post Number: 66
Ok guys!
Finally I jtag the pansat 2500a it's working!!!
the bin I used to fried that receiver with this bin
X-85BL_060609_277_au_api_
now what bin i sould flash it.
I see "PANSAT 2500A" on the front of recier
Username: Lklives
Post Number: 3592
Use 277T (not 277) to view DN and Bev TV...after the factory 222 bin to regain true FTA and clear any last residual corruption..
Username: Gunaa
Post Number: 67
Hi LK!!
How do I know my Receiver is clone?
other 2 receivers I have (lava 3000 and other one no name)I used the same bin (X-85BL_060609_277_au_api_)it's working.
I thought those are the clone.
Username: Yves_j
Northbay , Ont Canada
do any body know or to jtag my pansat 3500s it a clone it rigth now do not take bin up date it work perfect for 9 day then bang nothing i need help thank you
