I haev pansat 2500(Clone)I m not able to select any satellite for scanning.. I went to installationas and then antenna setup..here is I want to select some satellites..nothign work s infact none of the keys work here... is something blocking it ??? please help
If rebooting doesnt work... I would re-load the last bin loaded into that box and try again. if doesnt work, factory reset, load the factory bin and test the commands again. if works, try the new bin again.
