Bronze Member Username: MowafakgabalPost Number: 18 Registered: May-06 | Hi, I have Rex-I and I made a split on the Satellite Dish to add an new Receiver, the problem is All the Horizontale channels are working but some of the Vertical or most of them have No or Bad Signal? Any help, indea's? |
Bronze Member Username: MowafakgabalPost Number: 20 Registered: May-06 | I gave myself a problem guys, I need help, I had one receiver (Rex-I) with 3 dishes pointing to 97, 110&119, 148, I decided to be greedy and I got another receiver (SatCruiser 9000) and I used the following wiring with Mutliswitches http://www.sadoun.com/Sat/Installation/Multi-LNBF/4-receiver-4-lnbfs.htm since that I lost all Vertical feed from 110 & 148, can anyone help? |
