I need help!!!!
Username: Aaron55
i have two Infinity 10" Dual-Voice-Coil 8 Ohm Subwoofers with 250watts RMS each and i need to get an amp. What would be the best amp to get to make them work the best?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1781
dual 8? u sure not single 8? why did u get that... i mean thats vc config?
Username: Tjmutlow
Post Number: 2397
they do not make a dual 8, prob dual 4, if that is the case you can use a 2 channel amp bridged at a 4ohm load or a 1 ohm mono amp. if on a low budget, try audiobahn.....
