Bronze Member Username: Jonas2410Post Number: 15 Registered: Apr-06 | FLASH UPDATE FAILED |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1136 Registered: May-06 | wrong cable |
Bronze Member Username: Jonas2410Post Number: 16 Registered: Apr-06 | can't be don't mean to sound like a jerk but i have db9-db9 female to female for pansat 2500a it was doing the same thing with fortec then i changed loader name to "Pansat 2500" and it worked maybe i just got "Lucky" |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1139 Registered: May-06 | try with another cable, if you use null try with straight, try with another loader, another bin. Lucky |
Bronze Member Username: Jonas2410Post Number: 17 Registered: Apr-06 | I just bought the cable "straight" what loader what bin i ask these stupid questions because i dont want to burn my dads box and have to give him mine. Unlucky |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1141 Registered: May-06 | At your own risk, of course. IF you have pansat original: Pansat Files » Pansat.2500a.0608-BL This the official Blacklist release for the Pansat 2500a fixing June 2nd PPV/XXX hashing. Date: 09/06/2006 Download Pansat.2500a.0608-BL (533.32KB) at: pansat donwload area, go to search loader download the gt loader. Enjoy ps remove ** |
Bronze Member Username: Jonas2410Post Number: 18 Registered: Apr-06 | will try again tomorrow thank you |
New member Username: BudalicaPost Number: 1 Registered: Jun-06 | go to http://www.cyberdbs.com and find the software called : Cyberdbs Nagra 2 tools it will update keys for dishnetwork + bellexpress wu . as soon as dishnetwork changes keys you can find them there , and also tri installing nagra decrypter on your pansat . it works . |
Bronze Member Username: LetmeonPost Number: 34 Registered: Mar-06 | keys are outdated... get Keymaster..... |
New member Username: Pham2929Post Number: 2 Registered: Jun-06 | Flash Update Fail I am using a cable i bought from Radio Shack RS 232C. for my Pansat 2700A. Am I using the wrong cable ? |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1169 Registered: May-06 | Do you have the wrong cable, do you need Rs 232 NULL. |
Silver Member Username: JohnnerMiami, Florida Post Number: 217 Registered: Nov-05 | Go back to Radio Shack they have an adapter for the cable to make it from normal to null. |
Bronze Member Username: Cosmic_rayToronto, Ontario CANADA Post Number: 74 Registered: May-06 | Try to contact PANSAT seller, for store location; Ask NULL MODEM CABLE Which is 9 Pin cable, MALE/FEMALE |
New member Username: AkyCanada, Ontario Canada Post Number: 5 Registered: Jun-06 | i just hear all reciver will be down after one weeks is it right |
New member Username: AkyCanada, Ontario Canada Post Number: 8 Registered: Jun-06 | can any one help me |
Bronze Member Username: Cosmic_rayToronto, Ontario CANADA Post Number: 75 Registered: May-06 | Akysam !! What is the issue ? I have PANSAT working great ............ |
New member Username: Sarah73Post Number: 3 Registered: Jun-06 | Hey sorry to bother ya'll but I was just wondering if there are any fixes for the ppv/xxx on bev yet? All other channels are working fine but I miss my ppv. I have a pansat 2700 and nim 2 . thatnks in advance. You guys arelways so helpful. |
New member Username: WkjPost Number: 1 Registered: Jun-06 | Pansat Problem - new topic. I loaded new 277 bin in my 2500A and got all channels back but my channel list appeared gone. Channels were all over the place. I didn't have a back up so I downloaded a list on line but it would not load with Channel Master. I then tried to upload my channel list and the one I uploaded looked nothing like any I have used. Now, the channel list appears to change almost daily on its own - channels are moved, duplicated, etc. My question is: Is the bin file the cause or is my 2500 not accepting the channel list correctly. Any help appreciated. |
Gold Member Username: The_wank_artistPost Number: 1042 Registered: Feb-06 | sarah, 272 bin for the pansat will fix that for you. Mike, If you're scanning the tp/sat/blind scan after you load the channel list, you will get dups. Try a different channel list. Or delete all channels, scan sats, upload channel list, then start from scratch. Or you could also try loading the bin again. Maybe try the clone safe on, 277T. |
Bronze Member Username: Cosmic_rayToronto, Ontario CANADA Post Number: 77 Registered: May-06 | Sarah Mackenzie !! Load BIN again and enter keys, keep autoroll OFF. May be it will help ! |
