VORTEX-PRO 7700 need ur help
Username: New2thegame
Usa, North Usa
Hello,
I am using a clone vortex-pro 7700 with 2 satellites
1 Dual Direct Tv LNB (facing 119)
1 DNTV Twin Legacy (facing 110)
with 2 SW21 switches feeding 2 receivers 1 SUB 1 FTA
I am new and dont know much about software...this if what my system information says...
2.73t 4secGC_RTN_TVE Boot ver:6.0 18. Mar. 2006 Chancysand
I bn a paid DNTV customer for a long time...about three months ago I decided to purchase a FTA box from a friend. It was working fine until recent change of the PINCODE...which I did and I am still missing some channels. I dont have the R232 serial cable but I did order it off Ebay so i should be receiving it shortly. So my question is what BIN and loader should I use to start receiving all the channels again and what else can I do to my setup to improve it.
THANKS FOR ALL YOUR HELP IN ADVANCE
Username: Outlooker202
Post Number: 34
Follow this thread
it applies to u
https://www.ecoustics.com/electronics/forum/home-video/239992.html
Usa, North Usa
THANXS I WILL TRY IT AS SOON AS I GET THE SERIAL CABLE.
Username: Grimreeper
Post Number: 131
youll need to goto dsscomunity com there youll find lots of info.look for blacklist loader and 277t bin
Usa, North Usa
Got it...and oh yeah thats a great site.
thanks
Usa, North Usa
Post Number: 7
Can I use this cable to upload the bin through my computers com port.
6 Feet RS-232 Straight Cable 9Pin Female to FemaleUpload
Username: Lklives
Post Number: 3506
That cable should work with CORRECT SERIAL port, not USB port!
Usa, North Usa
Post Number: 9
I do have one in back of my computer. Thanks again.
Username: Lklives
Post Number: 3509
Must tell uploader software the correct comport..
ILLINOIS, ILLINOIS USA
Post Number: 10
Do you know how I could look up what port it is on. I tried the device manager but no luck. I am using windows xp.
ThanksUpload
Post Number: 11
It says serial 1 next to it so Im assuming it is on port1.Upload
Username: Lklives
Post Number: 3515
just try them all 1-4.. power PC OFF and hook up receiver and then power up PC...it will find correct comport!
Post Number: 12
Got it thankx.Upload
Post Number: 36
maybe he using the wrong cable
or try a different pc w/ same cable if it works it your pc has a problem
Username: Lklives
Post Number: 3525
He hasn't even tried it yet!...he's just asking before he gets into it..he will have NO problem..
Post Number: 13
Thank You for your help outlooker...but no I havent received it yet...hopefully by Monday...got it off ebay on wednesday.
Username: Wakenbake
Post Number: 215
i cant wait
READ dont ask
Post Number: 14
What are you implying WAKENBAKE.
Post Number: 15
Username: Wakenbake
Post Number: 217
if you did NOT know you had THE connection
on your pc then
many more ???
Post Number: 16
Its time to spark a B for me so ill hold back the qs til I get the cable.
Username: Lklives
Post Number: 3526
Maybe that U should just have read ALL this information FIRST,(it was posted everywhere here 1000 places about using the 277T bin with the vortex 7700 and how to use the correct cable and serial port and U cannot use SW21 switches with FTA receivers, except coo*lsat) and didn't need to post or ask, until at least U got your receiver and TESTED it first!
Post Number: 17
SORRY!
Username: Wakenbake
Post Number: 219
keep chin up
Username: Lklives
Post Number: 3528
Don't be sorry!...just THINK and READ first...U will have to replace a sw21 switch with a disque switch for that FTA receiver also..
This site has NO bins or files or manuals and guides..suggest U go to my thread topic "best Dss sites" and go to each web site and try and learn as much as U can about your receiver...if its EXACTLY like a pansat 2500 , then there are thousands of files and manuals to read everywhere, and its a super simple machine.....BUT first U must determine if it has its own procedures or is a total duplication/clonw of a pansat 2500..yes its a clone, but in ALL ways?
Post Number: 18
IM BACK...
I got the Digital DSW-41F DISEqC 4x1 2.0 Switch and the RS-232 Straight Cable 9Pin Female to Female in the mail yesterday. First thing I did was changed my SW21 switch (left my STB unpluged during this process). Then I went into the menu of my VORTEX and selected the factory settings and last but not least flashed it with
X-85bl_060610_277T_au_api__211 BIN.
(SPECIAL THANKS GOES OUT TO ALL OF YOU WHO HELPED OUT WITH THIS NEW BIN)
Had to rescan my 110,119,and 61.5
And GOT ALL MY CHANNELS BACK...
Thanks to LK n the members of this forum...
Post Number: 19
ALSO I DOWNLOADED THE
FTA GUIDE AND FTA MANUAL
TO HELP ME UNDERSTAND FTA.
Username: Lklives
Post Number: 3562
MIke...U are a smart man for reading and listening...U will find it much easier to learn this way...I will gladly help someone like U any day!...Effort means everything to me, not intelligence!
Username: Mauro
Ihave a vortex pro 7700 any one the new bin thanyou very much in advance
Username: Mauro
sorry guys Idon't read your post for the vortex i got the info.
