Good 600 watt RMS sub
Username: Utnc06
Hey I have a JBL 600.1 and was wondering what one good sub would be that is either a 10" or a 12" that works well in a small enclosed box. I want a SQ sub more than a SPL but I don't want it to be quiet. I have a Honda Civic 2 dr so I want it small and it doesn't need to be earthshaking.
Username: Utnc06
So far Im looking into these brands so if there is a relevant sub within this RMS and under 300-400 that would be great.
RE
Eclipse
JL
MTX
ID
Diamond
Others
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1136
u could get the treo tsx 12" or even beter the 15"
or the diamond d9 altho u would be underpowering it
Username: Dannyboyy
Peterborough, NH USA
Post Number: 117
sound splinter rlp-12
1.15-1.5 sealed
1.5-2 ported
Username: Basshead86
Google is your Friend, FL
Post Number: 3837
RE SE
W6v2
IDQ
D6
RL-i
RL-p
DD 2500
Treo TSx
Username: James1115
Ct
Post Number: 5962
Agreed^ also add eclipse allum, new v-max
Username: Utnc06
what are the RL-i and RL-p
also which would you consider better out of the SE, IDQ, D6 (assuming thats a Diamond), or 10w6v2
Username: Utnc06
Post Number: 7
or the new V-Max...i have the old 300RMS red surround VMAX ... is the new one better??
Username: Sw9152
Michigan
Post Number: 835
www.soundsplinter.com
Username: Utnc06
Post Number: 8
ok also compare the RL-p because that sounds great
