Wiring help
Username: Inafia
Cleveland, Ohio USA
Post Number: 35
as far as adding an amp to my components, how do i do that? i know u have to change ur wiring in the back of ur deck but i dont know what to do with them, also u have to attach both the factory speaker wire to the speaker and the one coming off ur amp correct? if some1 would email me a DETAILED walkthru of everything i need to do i would greatly appreciate it. juvenile132@aol.com
Username: Illuminator
Post Number: 3197
Put the amp under your front passenger seat. Run the speaker output wires from the amp up to the back of the head unit where the factory wiring is for the front speakers and connect the two.
