Username: Asharfi Post Number: 56 Registered: May-06
Sunday, June 18, 2006 - 01:19 GMT Hello, I just wanna know that which RS232 does Fortec Star Lifetime Ultra use? Is it the STRAIGHT or the NULL cable? And please tel me, what's the difference between them!!! Thanks !!!!
Username: Lklives Post Number: 3535 Registered: Jan-06
Sunday, June 18, 2006 - 01:40 GMT straight cable for that Ultra...they look identical...Null has pins 2-3 crossover, but U can't see it..
Username: Mrkvip Phnom Penh,
Kandal
Cambodia
Post Number: 30 Registered: Mar-06
Sunday, June 18, 2006 - 05:06 GMT Make sure the cable is line to line not nul modem. you can use the volmeter to check the connectivity line 1 to line1 ect...the null modem connect line2 to line3 of the other , line 3 to line2 and line 5 to line 5 of the other.
Username: Moreno36 Phoenix,
Arizona
Usa
Post Number: 3 Registered: Jun-06
Sunday, June 18, 2006 - 10:04 GMT what cables for pansat2500A please
Username: Grimreeper Post Number: 132 Registered: Feb-06
Sunday, June 18, 2006 - 13:18 GMT straight
Username: Lklives Post Number: 3538 Registered: Jan-06
Sunday, June 18, 2006 - 13:39 GMT c/p Ariza Ultra 400/500- Null Astrovox 2600-Straight DB9 Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)-Null Coolsa 4000 Plus-Null Coolsa 4000 Pro-Straight DB9 Cooltec-Null Coship (All)-Null Digiwave 6800/7000-Null Digiwave Diamond-Straight DB9 Dreambox (All)-Null Fortec lifetime-Straight DB9 Fortec Lifetime Ultra-Straight DB9 Lava 2600-Null Max 2500-Null ****sat (All)-Straight DB9 Microroyal (All)-Null Pansat 2300a/2500a and all clones-Straight DB9 Pansat 2700-Null Pansat 3500-Null Pansat 5000HC-Null(Also can program through USB) Pantec/Multistar Max (All)-Null Pantec/Multistar MS (All except MS1000)-Straight DB9 Pantec MX/Ultra-Straight DB9 Rex1-Null Silver bullet/ST 1000/2000-Null Skyview 500-Straight DB9 Spacestar DVB500-null Stealth 2000a-Null Ultrastar 5000-Null Viewsat VS2000-Null
Username: Assmmen SAN DIEGO ,
CALIFORNIA
Tuesday, June 20, 2006 - 17:42 GMT WHAT CABLE IS FOR CAPTIVE WORKS 600 S
Username: Pham2929 Post Number: 1 Registered: Jun-06
Tuesday, June 20, 2006 - 21:32 GMT what is the right cable for Pansat 2700A ?
Username: Satboy Ontario
Post Number: 191 Registered: Jan-06
Tuesday, June 20, 2006 - 22:41 GMT cable for C/W is a null modem cable
Username: Evadelparaiso Puerto Rico
Post Number: 1167 Registered: May-06
Wednesday, June 21, 2006 - 01:30 GMT pansat 2700 use null cable rs232
Username: C2so4 Post Number: 5 Registered: Jun-06
Thursday, June 22, 2006 - 14:39 GMT Eva, just sent you a PM, I'll Will appreciate any help
