Pansat 2700 Flash
Username: Babulal
Is the process of flashing a Pansat 2700 the same as flashing a fortec ultra? I have fortec and use al7bar flashing tool and it works great.
I try to use the same tool and latest bin file for pansat from dsstester (upload-1150041901-X-87BL_060609_272_api_2.bin) and I am getting Flash Failed message. When flashing for my fortec, I hit download on the flash utility once I see the first "night rider" light - i try to do that on the Pansat, and it doesnt work. Is there a different tool/way for pansats?
Also, how do you know if a pansat is a clone versus original?
Thanks for the help
Username: Babulal
Post Number: 7
Anyone??
Username: Lklives
Post Number: 3565
Pansat has its own loaders!...use any one of them...I prefer BL 1.4
Flashing/loading an ultra and a pansat are basically identical!....like driving a chevy or a ford!
Username: Evadelparaiso
Puerto Rico
Post Number: 1162
Pansat 2700 use null cable, except some clon than use straight. Gtroam loader download at dss**tester.com search loaders. Lucky (remove **)
