Splitting A Signal
Username: Tritip
Post Number: 25
I have the 110, 119, and 148 sat signals all coming through one coax cable. Is it possible to split the signal in the coax cable two ways and still receive all three sats on both coax cables. If so, what do I need? I tried regular splitters but they split the three sats and separate them two different ways.
Username: Bandizzy
Mi Usa
Post Number: 21
a switch box. if running pansat dp34 will work. running 3 boxes off 110 119 91 with one you can run up to 4 boxes
Username: Tadon
Dover, NJ Usa
Post Number: 65
You need Satellite control sw/. (DISEQC)
If you use a motor, it is OK .
But if you do not have a motor, how do you
get 3 Sat to your receiver ?
Username: Tritip
Post Number: 26
I have dish network dish with three eyes on it. It's set up to where all three sat signals from each eye is traveling through one coax line. So I'm trying to split the line two ways with out losing any of the three sat signals.
Username: Fortec16
Post Number: 33
connect the Diseqc one and the do blind scan and do an others....same way. u will have all thesignals
Username: Tadon
Dover, NJ Usa
Post Number: 66
You have 3 eyes in 1 LNB ? And has 1 out put ? (It means that has internal sw .) is that correct ?
now ,
"... I'm trying to split the line two ways with out losing any of the three sat signals "
is that you want 2 out put ? OR just only want
split to 2 rooms ? sorry I am confused ! :-))
2 option:
#1 . 2 out put mean you need connect to 2 Receiver (each receiver can watch any channel)
#2. 2 rooms mean 1 Receiver, both rooms watch
the same channel .
which one you need ?
Username: Tritip
Post Number: 27
Yes, it seems to have an internal switch. I want to split the signal in the cable that is carrying the 3 sat signals to run to 2 receivers. A standard splitter splits the sat signals up to where you don't get all three split two ways.
Username: Bandizzy
Mi Usa
Post Number: 44
sounds like you already have a dp34 switch hooked up . it;s a big squre box probably mounted to the pool under the dish you just need another cable and hook it to a "to reciever" output if not you probably running a DISEQC switch and need to upgrade to a dp34 $40 Bucks solves your problem.
Username: Bandizzy
Mi Usa
Post Number: 45
or find an abandon superdish and take the box! lol
Username: Hardrockstriker
Post Number: 128
I might be wrong, but I don't think that lnb will work the way you want it to with FTA. You may need to get another brand of lnb along with a 4-port disecq switch.
Username: Tadon
Dover, NJ Usa
Post Number: 68
Hi Tri tip,
a. Splitter can not apply for SAT. signal (before go into Receiver) due to the type of wave form .
b. Splitter can apply for SAT. signal from Receiver output .
Your case need 2 out put (2 Receiver)
Assume you only have 1 output from source (LNB)
So you need multi. Switch (3x4, 4x4 ... depend on what you need) for to get 2 out put .
From Input side of switch: cable from LNB --> input side SW.
From output side of switch: 2 cable --> to 2 input of your reciever .
hope this help .
