i just installed the new bin file that i was suppose too but still couldnt get any international channel to work so iwas wondering if anyone knows if i did something wrong or there is something more i need to do beside just installing the file...
this is the file i used x-05bl_060526_351eubx_db_au.zip
dose anyboby know what happen to the remote control on 3500sd , when i press channel ,menu ,etc ,nothing change . it look like it freeze , and i had new battery too , anyone thanks ...
yes ,i'm in sat mode and i have another remote control too 2700a they look the same ,but none of it work ,but sometime u get lucky turn off and on from the back of the receiver and it work again ,and sometime it take all day still not working i give up ...
International channels from which satellite are U trying to get?...be specific too, which channels on which satellite!...and whats your dish size and LNB type (linear or circular, DP or legacy, quad, twin , dual, single) and what are your receiver settings?..and switch type and port settings?...THIS IS A TEST!
