Pansat2700A, scrambled or bad channels!!!
Username: Freshbadboy
Post Number: 25
Hi all,
I downloaded the latest bin about 1 week ago and everything was working fine until about 3 days ago, when some channels started disappearing with message "Scrambled or bad channel". Most importantly ESPN2 which has the WorldCup games.
I did a blind scan but that didn't seem to fix it!
I am watching the games in some Spanish channel and since I don't speak spanish, I am not understanding much of the commentating ;)
Is there something else I can do to get my lost channels back?
Thanks
Username: Hardrockstriker
Post Number: 123
Did you delete your old channel list before doing blind scan?
Username: Lukasberglll
Metropolis
Mo, some of my channels stopped working too, but when I turned the receiver off from the back of it for about 5 seconds and turned it back on the scrambled channels started working again. Try it, it may work.
Username: Micklee11801
Post Number: 34
hey Mo,
try this! delete all the channels, rescan all the channels. after that, goto 8282 ture off the auto load for bev and dish. that will stop the Scrambled or bad channel. enjoy!!
Username: Ginijon1
Columbus, OH USA
I HAVE NOT BEEN ABLE TO GET PPV, HBO, STARZ, ENCOR ON MY PANSAT 2500A FOR 4 WEEKS OR MORE. ALSO WHEN I TRIED TO DO A BLIND SCAN EVERYTHING IS NOW CODED IN GERMAN AND I CANNOT DO A SCAN IN ENGLISH AND I DO NOT KNOW HOW TO GET THE ENGLISH INSTALLATION BACK ON MY PANSAT 2500A USING THE REMOTE. CAN ANYONE TELL ME WHAT IS HAPPENING AND HOW I CAN GET THESE CHANNELS BACK ON? ALSO I'M NEW AT DOING THIS AND I NEED TO KNOW WHAT A BIN IS, AND HOW TO PROGRAM . IF I NEED EQUIPMENT I NEED A LIST OF WHAT IS NEEDED!!!! LARGE PROBLEM BUT I NEED HELP.
Username: Evadelparaiso
Puerto Rico
Post Number: 1137
Gene, do you need read a little, search a little, you receiver need a new bin, go to dss**tester.com pansat area and download the right bin for your receiver, in dss search for loader and download the loader for run the bin. Unzipped both files.For ALL Pansats....
Things you will need!
1.A computer with a com port!
2.The right cable to connect to your computer to your receiver!
3.The most recently LOADER
4.New pansat bin!..
5.LNB setup and the right switch!
6.Sat Signal at 70 percent or higher!
1.Power down receiver and computer!
2.Connect receiver to computer and power both of them up!
3.Start up gtrom newest version and select the new bin file you wish to upload then click download wait until it is finished it will go to a 100 percent but it is not finish until it displays burn complete or finished!
4.Turn off power to receiver and computer and remove the cable from the receiver!
5.Install cable from the lnb and the cable from the tv and the plug it up and power up the receiver!
6.Using your remote hit menu and the parent control then ok in second pin enter 0000 and then ok!
7.Then set default key..EMU-ON then ok!
8.Go to Nagavision2 then ok and check 00 and 01 keys. Put in new keys if need then hit ok to save!
9.Now installation then ok antenna setup then ok make sure you have 110 and 119 and check to make sure the switch is set right for both on the diseqc setting! If 110 is on 1 and 119 is on 2, set diseqc the same way!
10.Now go to blind scan and hit ok!
11.When finished exit menu and watch tv
Puerto Rico
Post Number: 1138
Pansat 2300a/2500a and all clones-Straight DB9 cable
Username: Ibjay
Toronto, Ontario Canada
none of these bins work ob my pansat 2700a it kept on say inporewr bin file and my friend told u need a file for pansat to make go up to speed there hasnt come out so i dunno
Post Number: 26
Thanks for hijacking the post guys!!!
Lucas, the power-off and back on did work, thank you very much, but they go scrambled about 5 minutes later!!! Any idea what is happening?
Mikey Lee, I thought about removing all the channels and doing a rescan, but I am worried that I will lose some of the channels that are showing me the WorldCup games right now, so I will wait until after the WorldCup to do something drastic like that ;) lol... But definately I am going to do that because this is not normal.
For the short period of the world cup, any suggestions as to what I can do to resolve the scrambled channels, or should I just keep powering off and on?
Thanks as always.
MO
Puerto Rico
Post Number: 1161
Mo: Turn off all auto function, except keys, turn off auto dn auto bev, etc.
Username: Banzai
Post Number: 53
Hi guys,
see other suggestion from other thread as
https://www.ecoustics.com/electronics/forum/home-video/240757.html
