Rl-p12 eclosure.
Username: Dannyboyy
Peterborough, NH USA
Post Number: 90
is 1.75 cubic feet ported good enough. the web site said it was but sometimes they can be off. thanks.
Username: Langless28
Boston, MA
Post Number: 616
yeah when i get my rl-p its gonna be 1.75 cubes ported. tune the box to like ~29-30hz. it will sound amazing
Username: Dannyboyy
Post Number: 91
how can u tune it. i have a qlogic box already tuned to 38.
Username: Alteraudiousa
Concord
Post Number: 955
you can't really tune a Q-logic any lower unless you cut the back off or the side and extend the vent length, but isn't a Q logic a port tube and not a vent. I hate those. You'll be missing alot from the RL-p and probably won't like it with that box. I'd get a sealed one or a custom made vented box, and yes it'll do fine in a 1.75cu ft box.
Username: Dannyboyy
Post Number: 92
this is my box:
http://www.crutchfield.com/S-fOqLGkho3wq/cgi-bin/ProdView.asp?g=169550&I=044H171 2SS&search=qlogic
Boston, MA
Post Number: 618
if your gonna spend 270 bucks on a nice pice of equipment like the rl-p. i would recommend on a. building your own enclosure or b. find someone to build you one. cus your not gonna get the full potential of that sub outa that box
Username: Dannyboyy
Post Number: 93
k thank you
