Username: Biturbos4 Jacksonville,
FL
United States
Post Number: 7 Registered: Nov-05
Wednesday, June 21, 2006 - 01:04 GMT I do not have echo 8.6 on my sat list even though it was there before the update. What do I do TIA.
Username: Evadelparaiso Puerto Rico
Post Number: 1164 Registered: May-06
Wednesday, June 21, 2006 - 01:23 GMT go to select satellite, and select and scan.
FL
United States
Post Number: 8 Registered: Nov-05
Wednesday, June 21, 2006 - 01:43 GMT I cannot bc I do not have echo 8.6 in my list to choose from
Username: The_wank_artist Post Number: 1031 Registered: Feb-06
Wednesday, June 21, 2006 - 01:45 GMT add the sat via the installation menu. provider id 0101
Username: Johnner Miami,
Florida
Post Number: 218 Registered: Nov-05
Wednesday, June 21, 2006 - 01:49 GMT Just select any other sat delete all it's TP's and do a blind scan on it!
Post Number: 1170 Registered: May-06
Wednesday, June 21, 2006 - 01:50 GMT Do you need select the satellite, menu, installation, Antenna Setup, Select satellite, and set your configuration, for LNB, DIseqC etc.
FL
United States
Post Number: 9 Registered: Nov-05
Wednesday, June 21, 2006 - 01:57 GMT Thank you guys for the help but this is my issue: I cannot see a Echo 8.6 in the sattelite list when you go to the satellite, menu,installation, Antenna Setup. I have all the other ones including Echo7 but no Echo 8.6.... I need to get that on the list so I can assign it to diseq 2 etc... Tyler, where exactly do I enter the provider ID and will that solve my issue? TIA
Post Number: 1172 Registered: May-06
Wednesday, June 21, 2006 - 02:01 GMT go to, menu factory settings and let me know
Florida
Post Number: 219 Registered: Nov-05
Wednesday, June 21, 2006 - 02:02 GMT OK Alex select any other! --- assign it to diseq 2 etc... then goto TP/SAt and delete all it's TP's and then do a blind scan! It will work. PS if you want to can even rename after that!
FL
United States
Post Number: 10 Registered: Nov-05
Wednesday, June 21, 2006 - 02:02 GMT Tried that sevral times already, did not work. Also tried flashing with a older bin from April....still no help.
FL
United States
Post Number: 11 Registered: Nov-05
Wednesday, June 21, 2006 - 02:04 GMT Ok Johnner that makes sense..duh Thanks man...Tired can't think straight.
Username: The_wank_artist Post Number: 1032 Registered: Feb-06
Wednesday, June 21, 2006 - 02:04 GMT Do you have Echo 8,10 or something like that? If so, that's the new 8,6.
Post Number: 1173 Registered: May-06
Wednesday, June 21, 2006 - 02:05 GMT Do you can run channel master to add sat, tp or channels, if you still have this problem after reset factory settings, download master channel and add satellite, tp or channels.
FL
United States
Post Number: 12 Registered: Nov-05
Wednesday, June 21, 2006 - 02:14 GMT yes I have 8,10
Username: The_wank_artist Post Number: 1034 Registered: Feb-06
Wednesday, June 21, 2006 - 02:15 GMT D'OH!!! They renamed it to 8,10. Scan that one.
Post Number: 1174 Registered: May-06
Wednesday, June 21, 2006 - 02:15 GMT 8/10 its the same 8/6
FL
United States
Post Number: 13 Registered: Nov-05
Wednesday, June 21, 2006 - 02:16 GMT ok thanks guys.....
Username: Lklives Post Number: 3578 Registered: Jan-06
Wednesday, June 21, 2006 - 02:18 GMT Geez Tyler, I wonder who u got that from....LMAO There is NO more echo 8.6 ...its now 8/10 in the bins..since the new echo 10 bird was launched
Username: The_wank_artist Post Number: 1035 Registered: Feb-06
Wednesday, June 21, 2006 - 03:52 GMT Mine is still listed as 8,6 in the 272 bin?
