I am going to flash the new bin into my receiver and was hoping to hear from someone telling me it works ok... I have no channels at all, just a black screen and it states that the signal is scambled or bad... Hopefully the new bin 353 from BL with get this up and working.
please if it works drop me a line, and thanks in advance.
been using it for an hour or so. no problems so far. read on some othet sites that it would fix the occasional scrambled or bad channel problem. nobody there reported any problems so far.
i was having the same problem and tyler asked me to set the receiver to factory settings then flash the 352 bin again, do a blind scan..takes a bit of time,but it worked for me..
