FReq
Username: Caraudio
Toronto, Ontario Canada
Post Number: 408
THe back of my amp has Low High and Full.. On Full it sounds the best just curriouse waht these settings mean. Also my speakers rattle at high volume what could be the problem like somthings not working right could it be the garbage wireing from the deck to the speakers?
Username: Troy81
Tavernier, Fl Us
Post Number: 435
speakers or subs or tweeter?
tweeters, you want it set on high
speakers it depends, either high or full
subs, set it on low
those are filtering out either high or low
low filters out high hz
high filters out low hz that saves your speakers from bass
full is pretty much playing every thing
Username: Dustin3
Tigard, Or U.S.
Post Number: 1771
dont put it on full if u are runnin subs
Username: Caraudio
Post Number: 409
I have it on full pounds alot more tho.
