New member Username: Prar69
Post Number: 5 Registered: Jun-06
Posted on Anything out there for clones? |
New member Username: Outlooker202
Posted on unforunatly there is no support for CS clones that i am aware of. |
Gold Member Username: Lklives
Post Number: 3536 Registered: Jan-06
Posted on Here are the co*olsat CLONE bins for BOTH 1st and 2nd generation CLONES!...Software for 2nd gen and 1st gen Co*olsat clones. Examples Digisat , Ultrasat , CooCoo, Megasat 4000XL use 2nd gen file. first gen 3 button coo*lsat clones , Cooltech C/P from another site Proper Files For Cooltecs Alot of People are confusing which file goes in what receiver... This is Cooltec Class 101 For 1st Generation Cooltec Receivers...IE 3 Button or 5 Button...You will use the M2 File For Second Generation IE: Kooltec,Coo-Coo You will Use The "M" File. Use the right ones and ya got tv...These 2 are the OFFICIAL Releases.Sent Directly from Process99 and the fta-clone people... [link removed] |
Bronze Member Username: Vasia22
Post Number: 28 Registered: Jun-06
Posted on LK can u explane the difference between clon and original. If ill buy the Co"lsat 6000 do i need to download the bin in it or itll be there already?? |
