New member Username: RussreecePost Number: 1 Registered: Jun-06 | Hi guys, I am a newbie. I just got a silverbullet enforcer receiver and I hit the 119 sat (I think) What software and bin #'s work for June 18.2006? I am in London, Ontario, Is it possible I hit a canadian sat? All the channels say "scrambled" and they are canadian channels. Should I keep looking for dishnet 119? and How do I get it for free...lol |
New member Username: RussreecePost Number: 2 Registered: Jun-06 | Also quick update what is autoroll and how do I get it? |
Bronze Member Username: BandizzyMi Usa Post Number: 23 Registered: Jun-06 | ya have ta buy it it's an add on. $$ Raddio shack sells em. |
Gold Member Username: The_wank_artistPost Number: 1008 Registered: Feb-06 | If you're getting CDN channels, most likely you are off by about 8 degrees. Starchoice is at 111 degrees, either that or you're way of hitting BEV at 91 degrees. Turn your dish a bit to the left to get 119 (looking directly at the dish). Check out this link for most of the available sats. Notice *Choice at 111.1 and 119 at.. well... 119. http://www.lyngsat*com/packages/america.html |
New member Username: RussreecePost Number: 3 Registered: Jun-06 | Thank you very much. How much does autoroll cost? what is it excatly? Where do I get valid bin file to get free tv? Or can I just point at 119 and receive tv? What software is it? |
Bronze Member Username: BandizzyMi Usa Post Number: 25 Registered: Jun-06 | autoroll dont cost nothin its in the bin you download. sorry |
Bronze Member Username: BandizzyMi Usa Post Number: 26 Registered: Jun-06 | autoroll means the keys change themselves when charlie changes them. |
New member Username: RussreecePost Number: 4 Registered: Jun-06 | Ahh, thanks shlitz. Does the bin change alot? Do i need to hook my reciever up to my computer? And if I do does it require software to read/load bins , or do I just manually punch in key with remote? Thank not dumb just learning. tks again |
New member Username: RussreecePost Number: 5 Registered: Jun-06 | I understand. We call him Charlie do we...got it.lol. What is a good cdn price to pay for 3 months? |
Bronze Member Username: BandizzyMi Usa Post Number: 27 Registered: Jun-06 | keys you punch in with remote. bin can change alot dont expect free tv easy you have to put in the effort and keep up on it. bins for the bullet dont seem to be as plentiful as other receivers but i dont know alot about them maybe somebody else does. if it requires a bin you have to install in by your puter. |
New member Username: RussreecePost Number: 6 Registered: Jun-06 | ok thank you. Got the receiver at a yard sale for 10 bucks yesterday. I swore off satellite forever when dishnet went to yellow card. 1.5 yrs later I am back and I am out of the loop. Any help is greatly appreciated. Is the bullet obsolete or a dinosaur? Is koolsat 6000 where its at? |
Bronze Member Username: BandizzyMi Usa Post Number: 28 Registered: Jun-06 | E8 70 B0 0A 8E 0A 3D C5 F3 59 C3 5F 1A DA 19 5C 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC dish keys |
Bronze Member Username: BandizzyMi Usa Post Number: 29 Registered: Jun-06 | koolsat makes a nice box but im not sure your box wont work lets hope for more responses |
Bronze Member Username: BandizzyMi Usa Post Number: 30 Registered: Jun-06 | there is a guy who calls himself LK. he can probably tell ya. i just cant seem to fin any files for the bullet. he seems to know alot maybe he'll help out good luck to ya. |
New member Username: RussreecePost Number: 8 Registered: Jun-06 | Thank you so much, what a helpful spot! Cheers Do I punch in those numbers you posted? |
Bronze Member Username: BandizzyMi Usa Post Number: 31 Registered: Jun-06 | yep under nigra 2 |
New member Username: RussreecePost Number: 9 Registered: Jun-06 | where do I get n2? Is it shared out anywhere? |
Bronze Member Username: BandizzyMi Usa Post Number: 32 Registered: Jun-06 | it should be an option on your box like under parent controls or something. |
Bronze Member Username: BandizzyMi Usa Post Number: 33 Registered: Jun-06 | n2 is the keys. (numbers) |
New member Username: RussreecePost Number: 10 Registered: Jun-06 | ok, I will go look. Does this come up when I put on the computer? I just off the menu screen? Sry to be a pain. |
Bronze Member Username: BandizzyMi Usa Post Number: 34 Registered: Jun-06 | n2 is the encryption dish uses. |
Bronze Member Username: BandizzyMi Usa Post Number: 35 Registered: Jun-06 | tv screen option on the box. |
Bronze Member Username: RussreecePost Number: 12 Registered: Jun-06 | Hey if I am on strchc or bev can I just unlock those channels by typing in a valid bin? Not sure what sat I am on. I found a key ID screen do I manually punch in keys there? |
Bronze Member Username: BandizzyMi Usa Post Number: 38 Registered: Jun-06 | try it. |
Bronze Member Username: RussreecePost Number: 13 Registered: Jun-06 | I will thank you shlitz. Do I just put one bin # in? |
Bronze Member Username: BandizzyMi Usa Post Number: 39 Registered: Jun-06 | no you need 00 00, and 00 01. scroll to the right if ya can should get another set of numbers. |
Bronze Member Username: BandizzyMi Usa Post Number: 40 Registered: Jun-06 | 00 E8 70 B0 0A 8E 0A 3D C5 F3 59 C3 5F 1A DA 19 5C 01 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC dish keys |
Bronze Member Username: RussreecePost Number: 14 Registered: Jun-06 | Ahh, okay I will go to work on it. Thank you. This has been driving me crzy but I feel i will be here alot...Those dish keys work for *choice or bev? |
Bronze Member Username: BandizzyMi Usa Post Number: 43 Registered: Jun-06 | no bev keys D1 15 0C 8E 66 82 D9 80 90 A9 20 20 37 07 87 08 0C B7 0A F9 50 75 F3 5B 31 EC 79 97 5C D7 CE 1A |
Bronze Member Username: RussreecePost Number: 15 Registered: Jun-06 | I found the key ID screen. but I cannot scroll to the right. I can only enter the first set on bins. I looked around parental stuff and there is no other options. And thank you for bev keys too shlitz. Very helpful, I am just a dumba** This is what I see on my menu |
New member Username: FerociousdragonPost Number: 1 Registered: Jun-06 | Hi guys I was hopping to find out how to get my chnls back up and running. I got my box about 3 weeks ago . I'm at 119 d and when I set it up I used this code for nagra 2. 01- 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC Everything was going well, but about 2 weeks ago I noticed that not all the channels are showing up like hbo, ppv, adult... is there a new key code ? please help. thnx. Regards |
Gold Member Username: The_wank_artistPost Number: 1011 Registered: Feb-06 | Donny, Where have you been? There was an ECM back on the 2nd of June by DN. New bins were released the following week. You'll need to research your receiver, find which bin it uses and load it to the receiver. All your questions can be answered by reading some of the threads here. Just find a topic title with your receiver model and you'll be on your way soon enough. |
New member Username: Greegd1Post Number: 4 Registered: Dec-05 | i try E8 70 B0 0A 8E 0A 3D C5 F3 59 C3 5F 1A DA 19 5C 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC o colsat 4000 butmost of the chanells are lost is there new key ? |
Bronze Member Username: RussreecePost Number: 17 Registered: Jun-06 | How do I enter the keys on my receiver? I only get one set. It is a silvr bullet fta. I can only enter the first set of bins. I must be missing something??? Pls Hlp. |
Bronze Member Username: RussreecePost Number: 20 Registered: Jun-06 | Here is what I see |
Bronze Member Username: RussreecePost Number: 21 Registered: Jun-06 | Here is what I see |
Gold Member Username: The_wank_artistPost Number: 1013 Registered: Feb-06 | Where is says KEY ID and the 0x00 beside it, can you change that? That's the 00 key screen, you also need to add 01 keys which are the other 16 characters of the active keys. So I think you're looking for KEY ID 0x01 |
Bronze Member Username: RussreecePost Number: 22 Registered: Jun-06 | Not sure, once I enter the first set.. all I can do is exit out. Channel up and down cursors to next. Is there a manual or guide? If I hit BEV or *choice should it say where is says dishntwk? cause it is blank right now and I am unsure what sat I am on. I want 119, so when I do get it it should say dishntwk.right? Is this something that has to be hooked up to my computer? What is a good price for autoroll? Thanks guys... |
Gold Member Username: Maple_leafPost Number: 1463 Registered: Apr-05 | Man you are wasting your time you will never get it going. Call and subscribe. |
New member Username: Jonas2410Post Number: 2 Registered: Apr-06 | can i convert null to db9 with some type of adapter if yes where can i get it if not where can i get a db9 straight. i have both a 2700 and a 2500 thank you. |
Bronze Member Username: BanzaiPost Number: 47 Registered: May-06 | bal-0 - pansat 2700 needs a a null modem cable (pin 2&3 cross over) - pansat 2500 or Fortec needs a straight modem. you can find both of cables in any computer store ($6/each). Suggest buy cable & not the adapters. |
New member Username: Jonas2410Post Number: 5 Registered: Apr-06 | THIEN CANG thank you very much will straight say straight or should i just ask someone for help when i get there. thanx |
Bronze Member Username: BanzaiPost Number: 48 Registered: May-06 | Jonas IF you ask 9 pin Female-Female serial cable (it's straight cable), unless you ask NULL MODEM 9 pin Female-Female. If the saleperson looks confuse (some just got a job ). I suggest that you should ask some experience saleperson (because some of my friends got the wrong cable from the new saleperson). |
New member Username: Jonas2410Post Number: 6 Registered: Apr-06 | THIEN CANG thank you very much for all your help |
Bronze Member Username: RussreecePost Number: 26 Registered: Jun-06 | Hey Maple Leaf I cannot subscribe I am canadian. Does everyone agree I am wasting my time or is there a way to enter both sets of bin #'s and get some free TV..............Please HELP |
Bronze Member Username: RussreecePost Number: 27 Registered: Jun-06 | F**k This, I have a sh*t receiver, If anyone see this and can tell me how to enter more than 8 numbers. I can't even find out if this is actually a silver bullet, I can't find a pic of this receiver anywhere? I need a manual but can't find it. Any help would help help help. Thanks in advance. Russ |
Bronze Member Username: BouttepPost Number: 11 Registered: Apr-06 | i have a lava 2600 i need new bin for n2 and for ecm 06-02-06 |
Bronze Member Username: BanzaiPost Number: 52 Registered: May-06 | russ macdonald If your receiver is BB-ST1000, ST2000 or Silver Bullet Enforcer, you may go to Hope it help. |
Gold Member Username: LklivesPost Number: 3560 Registered: Jan-06 | Silver Bullet Enforcer was the top of the line for a very long time..ask any former member of pride3m.com... I belive there is a mod (JamesBond)at |
