Speaker placement before the walls go up.
Username: Sinnier
Hey All,
So I just bought my 1st home and have a 30 x 15 foot room to use as a home theater. The problem I'm having is I want to wire the system before I put up the drywall. Now the speaker placement is my problem. How do I figure out where the speaker wall jacks will go?
I don't have the seating yet and I wanted the floor to be in 2 levels.
If anyone has any ideas, please post.
The setup is a 7.1
Thanks
SINnier
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 209
Tyson this might be a little over the top but check it out. http://www.ultimateavmag.com/news/10388/index.html
Username: Mccambley
Post Number: 210
Tyson this may helphttp://hometheatermag.com/bootcamp/137/ http://hometheatermag.com/bootcamp/137/
Username: Sinnier
I'll take a look at these URL's when i get home later. Thanks.
I just don't want to put in wall jack, just to find out the should have been 2 feet to the left or right or up or down.
I know even seting it up the room i had it in took a bit to find teh sweet spots for the speakers.
I want to make the room right. I have the gear just never had a good room to set it up in.
If the room construction take a year that I fine with me.
Thanks
Tyson
Username: Sinnier
Casey,
This URL (http://hometheatermag.com/bootcamp/137/) is way cool. Its answers a lot of questions I had about different things. The room is barebones at the moment, so I can do whatever I want with it, and take as much time as I want.
It won't be a Million Dollar Home Theater but it will be the best experience it can be.
I'm also looking for a good priced Canadian shopping website for Home Theater Chairs & decor.
Thanks once again, I will share this website with others
Tyson
