Bronze Member Username: PiccaloPost Number: 46 Registered: Jun-06 | Hey guys, my friend has a QSAT 2500 PLUS receiver. Would any1 know what bin I have to use? Would appreciate the reply. |
Silver Member Username: The_wank_artistPost Number: 994 Registered: Feb-06 | Via eBay (it was all I could find on QSAT from Google) it looks like a Pansat clone. Load the 277T bin. Very important to get the 'T' in the bin. Otherwise it'll fry the receiver like some potato's in lard. FYI: Here's the link on eBay.... http://cgi.ebay.com/Qsat-2500-Plus-FTA-Receiver-Pantec-Pansat-Fortec_W0QQitemZ97 42666151QQihZ008QQcategoryZ32845QQssPageNameZWDVWQQrdZ1QQcmdZViewItem And the text... Qsat 2500 Plus is a Digital FTA Free To Air Receiver with MS Pantec compatible Software, it has a built-in STi5518 powerful single chip processor, fast Channel & Menu change. Qsat 2500 Plus will work, function and operate the same way as PANTEC, Pansat, Fortec, etc., but it is less expensive, it is friendly easy to operate, maintain, and update. And the small print: When dealing with a clone, always use the bin at your own risk. |
Silver Member Username: The_wank_artistPost Number: 995 Registered: Feb-06 | P.S. Before you ask, use one of these sites found in this link posted by LK. (He knows his shiz) |
Bronze Member Username: PiccaloPost Number: 47 Registered: Jun-06 | hey thanks bro, appreciate for the reply and the help. |
Silver Member Username: The_wank_artistPost Number: 996 Registered: Feb-06 | PT, No prob bro! |
