Pansat no ppv or xxx channels help?
Username: Zeus1111
Winnipeg, Manitoba Canada
Hey, can some lend me a hand? im a noob at this but i have entered in the bev codes provided by LK and they work. Before i have entered these codes in no channels worked at all, but now all channels but the ppv and xxx channels work. Im running off of Bell. Does anyone know how i can fix this to get the rest of the channels? Im missing ECW ppv!! Thanks to anyone that can help
Username: Nick32058
Asdfvafdsv, QC Sdv
Post Number: 97
What is your reciver model?
Username: Evadelparaiso
Puerto Rico
Post Number: 889
I have the same problem, but i dont have receiver lol just kidding.
Username: Zeus1111
my receiver models is the pansat 2700 (not the 2700A)
Username: Shl
I have pans@t 2500a and using bin 277 but I don have much channels. I delete all channels and tried to blind scan again but still not all channel comming in. any idea? Please help
Puerto Rico
Post Number: 893
Steve reflash your receiver with the same bin and let me know.
Username: Shl
Post Number: 8
thanx Eva. I'll try that and let you know
Username: Micklee11801
Post Number: 32
Travis,
use the new bin 272 for your pansat 2700a. it will let you watch all the chanels. make sure do a factory reset before load the new bin and use the new version of GT loader 3.4. good luck!
Username: Zeus1111
Thanks Mickey, but i dont believe i have the 2700a model.. ont he box in which i purchased my receiver it only says 2700. Is this the same thing?
Username: Lklives
Post Number: 3290
All the Pansat 2700's are the same...
Username: Zeus1111
okay, thanks LK for the new keys. How do i all the things mikey just told me to do? lol sorry, but i have absolutely no knowledge on this topic, i just want to fix my satellite.
Username: Scout816
where to get bin and loader???
Username: The_wank_artist
Post Number: 882
dsscentral*net
You'll need to be registered before you can download the bin, but it's free.
Username: Slimmaz
Post Number: 12
where can i get the loader for my bin can someone please help me im new to this. i really need ur help.
Username: Alehandro
Eva i have a megasat yt6688 what bit should i load to get ppv ? the latest keys are not working for my receiver
i appreciate your help!
Puerto Rico
Post Number: 899
THe last keys are not working to see PPV in none of them, do you need download and run a new bin program, go to dss**central.net and download the program for your receiver.
Puerto Rico
Post Number: 900
leticia: the loaders http://www.dss***tester.com/search.php?query=loader
ps remove ***
Username: Alehandro
but im not sure what bin to download, there is no bin for megasat yt6688, do you know what other bin is compatible with my model ?
thks !
Puerto Rico
Post Number: 901
Alehandro:
Mingo's Guide and files to get ur Cooltec or Megasat Pro Backup so U can use Mingos 128 Loader and Bin and Have all the features of the Cool***sat 128 bin with out the time bomb crap , If your Cooltec or Megast Pro was affected by the July 1st timebomb , you need to follow this info to get it back up and running ( need to jtag this in ) So that After you get it back up you can Use Mingo 128 bin and Loader and Get all the features of the 128 bin and Load with His loader and Not have to worry about anymore Timebomb crap , If you were luck enough to not get hit by the timebomb ( either someone warned you about it after it started and you pulled the Sat cable off before it happened or you were using the Pre- time bomb bin 124 ) then you can skip this step and go right to using Mingos Loader and 128 bin which I posted in these forums , if you already had a 125,126,127 or 128 Cool**sat bin on your Cooltec or Megasat Pro and the timebomb didn't go off because you Unplug the Sat cable before it Happened , I would advise flashing back to Factory Coo**lsat bin ( I think its 120) or 124 before using Mingos Loader and 128 Bin , but this is only for thos Lucky enuff that although they had one of the 4 mentioned time bomb bins on there Cooltec or Megasat pro they were lucky enuff to Pull the Sat cable of the Unit ( which Idon't think many were this lucky but there were a few after they start hereing about it on forums , Anyways here is the C/P from Mingo's post and the file to get your timebomb Cooltec or Megasat back up and running , so then you can Use the Mingo 128 Loader and Bin after you Have succesfully Jtagged these files in PDF Guide how to Jtag your Cooltec Here is the PDF and the filles to restore your Cooltec back to health. and a how to Jatag your Cooltec with auto roll. Hope this helps some one.
http://www.dss***tester.com/search.php?query=megasat+fix
Username: Alehandro
Eva thanks for the info, but i bought my megasat few months ago, like 4 o 3 months ago, i havent experienced the "july first bomb" my megasat turns on fine, the issue is that i have no ppv, hbo, adlt, etc. all them show me the "wait for picture" screen. So what im wondering is if my model is not a clone of panasat or someother, so in that way i could use a bin of other receiver to get ppv, did i explain it well ? and thanks again for your attention
Username: Zeus1111
after i download the bin 272 for pansat 2700, can anyone hel me as to how i actaully install it into my receiver.. if thats what you actually do? im new to this and dont know much about this sorta stuff. Any help would be great! thanks
Post Number: 893
Unzip the bin, save to computer.
open loader program (either GTRom or BL loader)
disconnect receiver from dish and turn off from back or receiver.
Connect receiver to computers com port 1.
Turn receiver back on from the back on/off switch.
Run loader program.
Select receiver model in loader
Select unzipped bin file.
Click download.
Call your parents and tell them that you love them.
Wait for download to finish.
Disconnect receiver.
Connect cable from dish to receiver.
Turn back power on.
Turn on receiver via remote.
Tune receiver to 'Knitting Channel' unless you're Eva, then turn to the dirty channels.
Enjoy.
Username: Min
I found the lastest bin files for pansat 3500sd already ,but i can't find the loader ,eva or tyler can u help ,thanks
Username: Min
Post Number: 7
can u use pansat 2700a gtrom loader v3.4 for the pansat 3500sd too...
Username: Zeus1111
Post Number: 8
Thanks Tyler!
Username: Zeus1111
Post Number: 9
d/ling and installing these bin files.. can it permanently fry my receiver? I mean like i have most of the channels already, is it a big risk? or is it fairly safe?
Username: Banzai
Post Number: 29
Travis Phung
Yeah, it'll fry your receiver for good, you may ask the PAN from Tyler (which fried my Pansat 2700a) ...kidding... :-)
If you don't know what your Pansat is (original or Clone), then I suggest use the safe BIN 272v1 from http://www.dsstester.**com/files.php?cat=14 (remove **) for your receiver safety precaustion.
1) Turn on your receiver -> menu -> Parent option at last row (second PIN) enter 0000 -> Turn ON everything in Autoroll Options -> exit to the root.
2) Follow Tyler instruction
3) Turn on your receiver -> menu -> Parent option at last row (second PIN) enter 0000 -> go to set default key & press OK to save the setting
4) prepare the popcorn if you watch the Vue## channel, otherwise call your lover if you watch the Venus channel lol
Puerto Rico
Post Number: 952
HGTv AND FOOD NETWORK ARE BETTER LOL
Username: Zeus1111
Post Number: 10
how can i tell if its an original or clone? It was purcahsed from an offical computer store that sold these kinda electronics.. so im guessing its probably an original?
Username: Zeus1111
Post Number: 12
Also, i would greatly appreciate if anyone can send me a direct link to the exact loader program and bin program that is right for me. I looked on the link provided by thein above this and there are 2 bin 272 files, one that fixes the june 2nd ecm and one that fizxes ppv and xxx hashing. Which one is for me if i have all cahnnels right now except for ppv and xxx? Thanks to anyone that can help!
Username: Vasia22
Post Number: 22
Guys plz need help! Tryed Almost evrythink! Forsat 2500 Ultra died after wrong bin ....
I tryed jtagless fixes , nothing worked ....
Build jtag cable , and used skymax wall jkey
still dead!
anyone jtaged this receiver ??! ANY ideas?
Username: Zeus1111
Post Number: 13
Oh yeah, also ion my reciever it says "pansat 2700-N2" is this an original ro clone? or is it ipossible to tell by that? thanks
Username: Lklives
Post Number: 3362
Both bins fixed the PPV's and adult channels...U need to do some scans or readjust your dish for strong signals!...and use ANY pansat or blacklist loader U want...it doesn't matter...I use the BL updater 1.4...some receivers prefer certain loaders, some receivers don't care..
x87BL 060906 272 bin is what U want for a GENUINE Pansat 2700...if Not sure, if its a clone receiver, then use the 272v1 bin with any loader U want!...BOTH get ALL the Bev PPV's and adult channels..
Username: Zeus1111
Post Number: 14
thanks lk for yrou patience with me and your quick responses, truly is appreciated
Username: Zeus1111
Post Number: 15
LK or anyone that knows, could you please send me a link to d/l the BL updater 1.4 ?
Username: Lklives
Post Number: 3370
here's ALL the Pansat bins, loaders, Jtag manuals, input key Guide, etc...
[link removed]
Remove the * in both links...also must register first FREE www.dsscommunity.c*om
Username: Zeus1111
Post Number: 16
greatly appreciated LK thank you!
Username: Zeus1111
Post Number: 17
k awesome.. LK i downloaded the bl loader that you have and i have unzipped the bin file and eveyrhting.. everythings ready to go..how do i use this loader? which com should i choose? do the instrucitons that tyler supplied me earlier on in this thread still work for this? i dont see a place where i choose my receiver model. This loader looks really simple to use, could you breifly explain hwo i transfer the bin onto my satellite? thanks LK or anyone else that knows how to use bl updater 1.4
Username: Zeus1111
Post Number: 18
also, Mikey mentioned early in this thread i must do a factory reset before i load the new bin.. what is a factory reset in a nutshell and how do i do it? thanks!
Username: Lklives
Post Number: 3407
with BL 1.4, U don't need model name...and factory reset is not a necessity..U sound like a newbie who has never done this before, so TEST away!
Here is how to recover from the "Night Rider" (flashing lights):
1. Try re-flashing the factory boot/flash again using the below directions. That gives you FTA ONLY. Follow the above procedure.
2. Then, when that works use the latest flash to get the scrambled channels.
3. Download a channel list and/or do a channel scan on each sat.
4. When flashing, be sure to wait not only until is says done. But you need to wait until it reboots and actually goes to a channel number.
Here are a few tips if you are having difficulty flashing: loading a bin..
I would advise everyone to read a set up guide before flashing. But, since people have been having some problems, I have revised this to provide more detailed information. But this is not intended to be a substitute.
1. Make sure you use the proper serial cable for your receiver:
Most Fortec and Pansat use a straight through cable with DB9 females on both ends.
The Blackbird, Pansat 2700/3500 and some other receivers use null (crossover) cable, which crosses over pins 2 and 3.
2, With the power turned off, connect it to your computer and receiver using the serial connector. Use serial port #1 if you can.
3. If you do not have a working SERIAL port, you must install one or use a computer that has one. Usb ports do NOT usually work, except on rare ocassions with an adapter.
4. Use the appropriate loader.
5. Select the file. Make sure that it is the correct flash for your receiver.
6. Select the COM port your receiver is connected to. If you do not know, what it is try #1 first.
7. Enter the correct model name and number. Most Blackist updaters do Not require this.
8. Check off the correct function box. Your choices are boot, flash or channel list. To FLASH your receiver you would use FLASH. Most flashes do not require a separate boot; so do not load both separately.
9. Turn on the receiver power from the BACK switch.
10. As soon as you see the lights flash,very first light -- IMMEDIATELY press download. Timing is critical and many vary.
11. Wait until it COMPLETES and reboots
Next U need to do a satellite scan of whatever LNB's on dish are aimed at....then set default key..then EMU-ON...and U also have to configure the receiver settings to your LNB's type and disque ports..but had U read the manuals U would already know all this..
Username: Shl
Post Number: 10
I'm watching Bev from cs5k and pansa@t2500a, and i get most of the channels, but not p0rn. could some one tell me how to get those please. thanks
Username: Lklives
Post Number: 3413
need another scan!...unless U have some parental controls ON..
Username: Shl
Post Number: 12
yeah i did scan, but no luck.
can we use the same bin for dn and bev (277 pans@at 2550a and 123 cs5k)
Username: Lklives
Post Number: 3415
yes DN and Bev are together on all bins now for past 10 months!
there is nothing else u can do...scans is how U locate missing channels, or channels which have moved to new transponder or new satellite..
For U to be missing ALL the Po*rn channels on Bev (many) with 2 different receivers is impossible, unless U need to realign the dish and improve the signal!...thats the ONLY thing they (both receivers) have in common!
Username: Banzai
Post Number: 31
Hey Stevie Wonder ... oufff... Steve NG.
What's your signal level on those 2 SAT (Echo & Nimiq). My is above 70% and I got all channels. Perhaps you try the Blind Scan on those SAT to get all TP. Good Luck :-)
Username: Zeus1111
Post Number: 19
Hey LK , im confused as to the instuctions you provided about recovierng from flashing lights. My lights on my receiver are fine, im just trying to fix my cahnnels so i get ppv and xxx and can i just fix that just by connecting my receiver to my computer with an RS 232 cable and then load the 272v1 bin to my reciever with the bl updater 1.4 loader? im not sure what com to use, so ill try what you said and start with #1.. would this fix my receiver?
Username: Zeus1111
Post Number: 20
also, "clicking download" is equivalent to "write bin" on BL updater 1.4 correct?
Username: Lklives
Post Number: 3442
Travis...the flashing lights was a BONUS for when U screw up your loading the bin next!...I also gave U the info how to flash a bin!..and of course those are the same, download and write!...little common sense here!
Username: Zeus1111
Post Number: 21
Does the dreaded "night rider" always occur when flashing your receiver? also, to hook up my receiver to my computer it looks like i need a RE 232 cable which has 9 pins.. will this work?
Username: Zeus1111
Post Number: 22
ah i see thanks a ton LK, im just being extra sure cause id hate to kill my receiver lol. k thank you LK for all your help if i need anymore i will repost.. i will get the RS 232 cabel shortly and will deff repost to say how you saved my receiver.. thanks again LK i really appreciate it
Username: Alehandro
Post Number: 11
LK i cant find the bin for my megasat yt6688, how do i know what bin to load ?
Username: Zeus1111
Post Number: 23
WHen flashing the bin, should both compute rand receiver be turned off when plugging in teh cable? or just receiver? thanks
Username: Lklives
Post Number: 3476
lets not get anil now...just follow the steps above...PC must be on for U to select the "appropriate loader" (software file).. THINK a little on your own!
Username: Zeus1111
Post Number: 24
i know, thats what i was thinking, but i read eva's insturcutions in another thread adn seh said computer and receiver both turned off so.. so i asked jsut to double check.. im a 16 year old kid trying to fix my dads receiver, im nto quite knowledgable in this department... so sorry for all the headahces ive caused lol
Username: Ijazsyed
Post Number: 9
hi I have a pansat 3500s I am missing indian and pakistani chanels please hlep me to get it back thanks
Username: Markb582
Travis or anyone else. I am new to this and here is what I want to do with my SAT-B55 receiver (i know it is old but it is reliable) I am willing to change it to something faster if need to. I am spending so much money on direct programming, not to mention the PPV and other channels. Can someone point me in the right direction..email me if you prefer Thanks so much.
Username: Banzai
Post Number: 38
Travis Phung
Don't worry even you fried your dad receiver, he cannot lay a single slap or yell a magic word because you're untouchable (minor - under federal protection), is it cool?
For the connection:
* PC is always on (unless you open your PC case to upgrade something or nothing to do with the PC),
* FTA receiver on stand by mode which means the button behind the receiver is ON but nothing appear on the TV when it connected (only time appear on the LCD screen of your receiver).
* Connect the cable from your PC COM port available (most of the case is COM1) to RS-232 port of receiver
* Launch the BL 1.4 or GTROM V3.38 loader (application)
* Verify your COM port setup (make sure that COM port is fully functional, if U doesn't know how then ask your father :-). U fix his receiver then he must lay a hand on your PC unless the PC belongs to him :-()
* Select the BIN file to load (be careful, you have to pick the right BIN for your receiver, otherwise it'll fry the receiver in the next day)
* Press download (I confuse with this one why it calls download when a file upload from PC to receiver, if we run the loader from receiver then it may call download :-(()
* Wait until it finish then turn OFF the button bind FTA receiver and unpluge the cable
* Turn ON the button behind FTA receiver make sure something appear on your TV while both connected, if not then turn ON the receiver from the remote control.
* go to Menu -> Parental Control -> press on user default setting to save the setting that you did above
* Verify if there is any channel. IF not, menu -> Parental Control -> channel edit -> delete all Channels. Then menu -> installation -> blind scan all SAT which setup on your receiver
* Enjoy the show....
P.S.: I'm always blind scan whenever I load a new BIN, so I don't miss any new channel just release.
to ijaz syed:
which SAT that your dish point to?
do a blind scan
Username: Shl
Post Number: 14
I'm not too worry about my pans@t 2500a 'cause it slow like a turtle. but on my cools@t 5k i have signal level on those 2 sat above 93%.
I'm wondering whether because i use dp plus lnb that may cause the problem??? I loop 91w into the dp plus lnb then i have 2 output to the 2 fta boxes.
"What's your signal level on those 2 SAT (Echo & Nimiq). My is above 70% and I got all channels. Perhaps you try the Blind Scan on those SAT to get all TP."
