Need help with my pansat 2500a!!!!!!!!!!!!!!!!please
Username: Mcuachrp
I downloaded a bin into my pansat 2500a and after it finished loading, it said complete on the computer, but the box showed lines goin fron side to side lik it was still loading, so i left it lik that for about 5 min n it didnt stop, so i turned it off, then i turned it on and the same was happening. I tried downloading factory bins into the box, but the dash just started going from side to side faster and doesnt stop. Please help me , i dont know what to do!!!!
Username: The_wank_artist
Post Number: 1045
Knight rider lights.
Get factory bin read to load to receiver.
Once you see the first light start to go across, flash the bin.
If that doesn't accept it, start again and wait for the 2nd light, and continue until you run out of lights.
If still not working, then start at the first again and stay on the first.
Remember it's all in the timing so it may take you a while.
And I hate to have to tell you this but it sounds like you have a clone. So when you've got the factory bin installed, go get the 277T bin (clone safe) and use that and all clone safe bins moving forward.
