HDMI and DVI
Username: Kdhtime
I am interested in purchasing a DVD player that upconverts formats to 1080i. From what I have read you need to use the HDMI for the signal. I have a Westinghouse TV with a DVI port. Can an HDMI signal be sent to a DVI port? Will I still get the upconverted signal? Thanks
Username: Jaday
SC
Post Number: 15
Yes, you can get an HDMI to DVI connection... just make sure you send audio as well into the tv or receiver that you're using
