Lava 3200 display stuck on (ON)
Username: Ww228king
Post Number: 9
ok my lava 3200 is a pansat 2500a clone....it was working fine then somebody told me to try a blind scan to get my locals...so i did a blind scan then i had some off the was transponders and like 5 channels....really mested up...so i went to echo 7 and did a all transponder scan...well, if showed in the menu that all my channels was back to normal, then i went to a channel and i could hear sound but no pic, so i turned it off with the back switch then on....i was ok for about 3 sec, then the screen started to flash then i turned the back switch to off....then when i flippped the back switch back on, the night rider lights start the stop and shows (ON) and thats it...and the tv screen goes black...front buttons nor remote will work...please help....need lava 3200 factory boot bin or something...thanks
Username: Ww228king
Post Number: 10
one more thing ..my email is ww228king@aol.com
Username: Ww228king
Post Number: 11
well does any body want his piece of crap.....sence nobody has one with the factoy boot bin or help
Username: Evadelparaiso
Puerto Rico
Post Number: 1009
IF your recently install a bin in your receiver, try reinstalling.
Username: Dafee99
Post Number: 120
The 277t bin has epg. everytime you turn the receiver on and off, you need to give the receiver time 1-2 minutes to download the guide.
Meanwhile, it will display "ON" if you dont want the guide or simply press exit. or press ok and wait 1-2 minutes until the channle displays...
Username: Netdss
Jason / Eva , I have the same FTA a LAVA3200, right now I can't see any channel, could you tell me what I have to do ????
Which are the keys that you are been using now ???
do I have to do something with the programming ???
