New member Username: BerlinCalifornia USA Post Number: 4 Registered: Jun-06 | I have 2 Viewsat 2000 Platinum, I downloaded wrong bin, Apt-get & satinfo file to the 1st receiver, and the 2nd one with the right bin works great. My question is : Can I upload from the 2nd receiver that works fine to the one that I mess up? Does anyone know how to do it? should I upload from the 1st receiver to my PC and then load it to the 2nd receiver or there is any other method to do that, plz need your expertise here. Thanks alot |
Bronze Member Username: Outlooker202Post Number: 14 Registered: Jun-06 | DAMN, you gotta read your sentence structure (....upload from 1st to my PC.....) <----make no sense The method you are trying to describe is CLONING Plug in 9pin NULL CABLE in both VS Using the good ird(reciever) turn on and watch any channel Now turn on the dead/non working IRD it should start transfering the data (everything, CHA, SAT, CODE, OS (bin)) just press okay if the status bar stops. it waiting for approval. Yes, you can |
New member Username: M_onoratoPost Number: 1 Registered: Jun-06 | I need the loader2 for the viewstat 2000 platinum |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1057 Registered: May-06 | remove ***. Enjoy |
New member Username: AzpridePost Number: 7 Registered: Jun-06 | hey EVA, which cable to connect the receiver and computer? 9 pins connector? then what? i tried 9 pins ( F to F), execute loader2, but still sit there, nothing happens?????? help please |
Silver Member Username: BoycePost Number: 282 Registered: Apr-06 | https://www.ecoustics.com/electronics/forum/home-video/240311.html |
New member Username: BerlinCalifornia USA Post Number: 7 Registered: Jun-06 | outlooker202 : Sorry to make you confuse with my sentence, my mistake. (What I mean ....upload from the good one to my PC then download it to the dead one... :-) ) Anyway thanks alot for your help. |
