Archive through June 15, 2006
Username: Naren3001
MR. FAZAL,
IT SEEMS THAT YOU ARE A GREAT HELP FOR EVERYONE HERE, CAN YOU HELP ME TOO?
I HAVE COOLTEC, AND I DONT HAVE ANY FILE YET, YOU HAVE ANYTHING FOR COOLTEC?
THANKS
Username: Babi
Post Number: 11
no I did not move the dish, even my friend don't have signals in 121 both of us using linerLBS only even I change the LNB to new one and I chaned diseq switch too. and Yes I have CS5000
Username: Giftmenia
Post Number: 33
i will answer your all questions within 6-7 Hrs
INDOPAK UNDERWORLD GROUP (IUG)
Username: Azzurri
Post Number: 21
if you changed lnb, check direction again, diseq switch on, set lnb 121 for committed number 3. it sounds like you need to check you satellite settings, cable from 121lnb to diseq switch 3 to match settings
Username: Babi
Post Number: 12
i have my dish in my window I I tried several time changing position and I have a mark on the dish which it was working too.Do you know any one using this 121 W so that you can please ask them they are getting or not may be my receiver is gone
Username: Mat_nelson
Thanks a lot, Fazal and thanks Madona Ferguson. I now have Winzip but the files are opening in a machine language and I don't find GTROM loader there too.
Pleeeeeeeeeeeeeeeeeeeeease help. I am getting frustrated.
Username: Chababe
hi fazal
please can this files help for my REX-I receiver.
please tell me
with my love
Username: Azzurri
Post Number: 22
danny, i get full green signal on my 121, i loaded 123 as usual and all works fine.
Username: Cosmic_ray
Toronto, Ontario CANADA
Post Number: 37
Mat Nelson,
You have to EXTRACT, LOADER and BIN files at DESKTOP, ..........ne need to open...
Open LOADER and Click BIN and browse BIN File........when comes in column, click DOWNLOAD
Make sure your receiver connected to PC properly..
Download progress will show on PC Screen and Receiver...........when 100%, Turn OFF and connect to your TV and enter KEYS............and ENJOY !!!
Username: Nydas
Post Number: 8
Pansat 2500 clone. I had problems of weather and transportation, so I decided to spend $30.00 at the local flea market. He was updating a queue of customers.
The Indian/Pakistani, Japanese, Arabic, PPV, Pron are all working. The Rom shows the following:
X85BL
API 2.77Ta-EU
Bootver 5.1
10 June 2006
Tivo-RTN-TVE
How long this will work, I have no idea. I just want to inform everybody that the new BIN does work. The Keys seem to be the same.
Post Number: 38
NALIN................
You spent $ 30.00 bugs, what you can get easily if you read this forum regularly, especially AFZAL is doing such a fantastic work, he is genius !!
Username: Babi
Post Number: 13
Dear Fazzuri
Is it a key problem then or receiver can you give me the keys from ch 8282.
nagr1 10,11,20,21
nagra2 10,11,10,11
nagra3 00,01,10,11
Username: Sliderip
hello, i got a simple question from all the desi people.
thinking to upgrade my FTA box, per LK i should get Viewsat Xtreame. Just wondering for some input from people who have both VS and/or Colsat/Pansat.
We can say that VS seems to have best support, at least for now. But how their dhanda compare to the compition in terms of ease of use and quality?
Anyone with objective input
thanks
p.s. best place to buy it at good price?
Username: Kashif4u
Post Number: 8
Dear Fazal Many Ppl are still waiting for your answers.
Username: Srg200159
Post Number: 7
where do u get the loader from
Username: Srg200159
Post Number: 8
how do i get pansat loader
Username: Sobia
Hi Fazal
Im new so plz help me...
I have FORSAT with remote label DVB. How i can install bin files/ keys, coz i dont know anything,, plz help me...
Thanx
Username: Milla
Edmonton, Alberta Canada
Post Number: 40
is the bin 277t for the fortec ultra the same as the one for the fortec lifetime?
Post Number: 47
Tony Khan !!
It seems that PANSAT is better,
You can get good price at following place, I did either !
Electronics Canada Plus
1358 Kennedy Rd. Toronto, ON, M1P 2L7
Tel:416-693-0929
Web: www.ecanadaplus.com
Username: Johnny0786
Here is the story there is no change on any thing but BIN files and some new keys I have all the channels working including PPV and International.
Username: Giftmenia
Post Number: 34
FIND YOUR NAME AND ANSWER
Message for mukesh patel, seeba, dle, gary, naren, chababe hazem,
http://www.freefileupload.net/file.php?file=files/100606/1149928143/X-85BL_06060 9_277_au_api_.zip
Message for Moin ahmad,
Use this file
http://www.freefileupload.net/file.php?file=files/100606/1149928462/X-05BL_06060 9_352eubx_api_au_1.zip
or try this one
Message for danny don
Use this file
http://www.freefileupload.net/file.php?file=files/100606/1149928530/X-95BL_06060 9_3097_api.zip
or try this one
Message for Khurram Khan
Yes This is your file
Message for Shane VORA
Yes you can use that file.
Message for abu elshabab Yes use 277
Username: Giftmenia
Post Number: 35
FIND YOUR NAME AND ANSWERS ARE NEXT TO IT
Use this file
or try this one
Use this file
or try this one
Username: Giftmenia
Post Number: 36
Peanut i will be uploading blacklist loader tommorrow so you can easily download file to your reciever
PLEASE SOME BODY HELP AMJAD ALI.. DONT BE SELFISH.
Username: Ismailbawa
bro fazal can u plz tell me what sould i do i have ariza 500 is there any file or anything to make it work plzzzzzzzzzz help bro
Username: Rocks
Iselin, NJ USA
Does anyone have BIN for CooCoo 4000 pro
Username: Rocks
Please help for coocoo 4000 pro file
Username: Imtaisal
Post Number: 28
hi
any one halp me when i off my reciver my all indian channels blank every.when i on my re i need again scan .for ariza 700 how i can ix this problam
Username: Sdgodfrey8
Post Number: 11
Faizal,
Is there a fix for a Spacestar 500 receiver?
Thanks.
Username: Evadelparaiso
Puerto Rico
Post Number: 842
Sabina: do you download the last bin for fix Indian channels?
Puerto Rico
Post Number: 843
For spacestar not yet.
Puerto Rico
Post Number: 844
Ariza Fix:
http://www.dss***tester.com/files.php?cat=21
remove ***
Username: Veeru
Hi Fazal
Do you have fix for Microyal 1200?
Please and thanks.
Username: Rocks
Is CooCoo a clone of Cool*at
Username: Naren3001
Post Number: 11
Thanx Mr. fazal for the file but this file i am not able to download to my cooltec 4000 as my loader accepts only .stb files
Can you help me with this?
Username: Naren3001
Post Number: 13
Anybody has the fix for cooltec 4000?
Username: 451682
hey fazal...bro i used the bin file u told me x-85bl_06...that one thru blacklist stb updater 1.4.0.0...after it was done scanning...the channels that were coming from echo 6,8 ...they're gone too soo plz tell me what to do bro...and now nothing is coming at all ... last time this happened all i did was i inserted the key number thru nagravision 2 and it started working ... and i have a fortec ultra ..lifetime reciver...so plz a lil help here bro...thnx
hassan
Username: Gemtomas
Hi
Very good forum and best help.
Can you help? I can't find the russian channels those was on eco9.I can find Indian channels and ppv s but russians no.I have co**lsat 4000 and newest bin.I did search in this forum but i did'nt find about russian channels or maybe i miss somthing or i did wrong search.
Help me plz and Thanks alot.
You cand send me answer on my email gemtomas@yahoo.com
Thanks
Username: Babi
Post Number: 14
I have c00lsat5000 and I loaded 123 bin I am getting all channels in 121 W but when I go to menu and dish setting under 121 W Echostar9 there is no signal at all even I move all satellites no signals. why
Any body please tell me regarding this......
Username: Paulp73
Any ideas on when we are getting the New Keys for Fortec Lifetime...for the Indian channels?
Username: Itguy
Post Number: 8
ANYONE HERE WITH A WORKING FORTEC LIFETIME CLASSIC NA? I NEED TO GET ALL THE SOUTH ASIAN CHANNELS BUT EVEN AFTER GETTING THE LATEST BIN FILE, IT KEEPS ON SAYING 'PLEASE WAIT WHILE THE CODE IS BEING UPDATED'. AFTER A WHILE IT WOULD SAY 'SCRAMBLED CHANNEL'.
ANY HELP IS MUCH APPRECIATED.
Username: Eng590
hey guys, !!. i have a small problem. i have pansat2500. i downloaded the 277.bin which is safe for clones. well. when i turn on the reciever, there is no picture on the screen. as in the whole thing is black. no option for language selection. nothing.it powers on, but i cant use the receiver. so i downloaded the original bin,. back on and everything was back to normal. so what do i do, in order to watch the channels again. what bin should i download?.. thanks to anyone and everyone. who replies.
Username: Sobia
Hi Fazal
Thanx
Username: Bbc002
Need the BL loader for pansat 2500a clone.
bbc002@hotmail.com
thanks!
Username: Sobia
Hi Fazal
Thanx
Username: The_guru
Florida, Fl Usa
is there a fix for cools@t 400 pro
pls provide link/file..you can email me
thanks
Username: Mysticplay3
Please help.. I have a pansat 2700A and I have put a second dish with brandname LNB of DN (may be old)I have tried to get the Indian channels at 61.5W but just can't get the signal. My first dish is working OK at 119W ECHO7.
Username: Nydas
Post Number: 11
The angle for the Echo 3 (61.5) is more south and less skywards. Go to Lyngsat and find the angle. Also you will need a desq, which is a device for chanelling two satellites to the same TV. For example, my Echo 7 is connected via terminal three of my desq, and the echo 3 satelllite is connected via No.1 terminal of desq.
Username: Harycd
I have Pansat 2500, could someone please send me uploader and bin file @ hangurala@hotmail.com thanks
Username: Shaikh
HI guys
i am new and i want a file for cooltec can anyone help me and othere thanks.
Username: Gunaa
Post Number: 39
Hi guys!
any boddy know whare can i find the BIN FOR CO@LSAT 5000, and what is the DVB model neme that i have to type (DVB....)?
fazal bro plz help me i have ariza 500 how can i make it work sand me bin or any information about ariza500 plzzzzz thank u very much
Post Number: 56
Hi !
Fazal,
Thanks a lot you sent link particularly mentioned my name,
That helped me I .......
How may I help other and you ?
LOVE !!!
Username: Main420
Post Number: 50
hey gunaa,
go to dsstesterdotcom, and look under the files for c00lsat receivers and u will find yrs
Username: Steven_man
Post Number: 21
Anything on the Fortec Lifetime Classic NA. The 060706 bin file does not work. Thanks
Username: Tasha01
Post Number: 13
Hi, does anyone know how to get dishnet 121 back? (the indian channels).
Username: Ariza
Post Number: 21
lol what is BLACKLIST LOADER????????????????
and pansate bins can work on ariza700?
Im new to this but this is what im going to do when i purchase my null modem cable tommorow
im going to load this file
http://www.dss tester.com/download.php?file=696
IS THIS WHAT I DO? Hook up the null modem cable from my receiver to my pc and load the bin into the software then press "download?"
my ariza700 software came with a bin named "700 factory flash" does this have any significance?
just want to know everything before i make any moves, and i want to get the right bins so i dont have to jtag my reciever
Username: Mana
Maple, ON CANADA
Hi,Fazal
Thanks for sending the link.its working
Post Number: 7
Thanks FAZAL, thanks Madona Fergusan:
Thank you thank you very much. My pansat is working well and I am able to see my favorite channels again.
You know, it was the wrong cable that was the major problem. Today, I changed the cable and tried files sent by you and procedure told by you. And here it goes. The machine is working.
I hope, you understand how grateful I am to you.
Thanks again.
Username: Drpaulomi
Ss, Ss Usa
Post Number: 15
hi ! Guys..I uploaded New bin suggested by Fazal ( 352) now it worked and i was getting all the channel but suddenly today my TV screen is blank as if there is no connection between TV and PANSAT..I have checked all my wire..I don't see anything on My TV screen...( Just rain drops) ..can u guys help..My tv works and also my Direct TV works on same TV..But pansat is not working..Is this a problem with new bin..Let me know the solution..
Username: Ladym
Does anyone know if there has been a fix for the Ariza 400 and 500 receiver for international channels. Please let me know. Fazal...you seem to be the great helper...any suggestions??
Username: Giideh
does anyone have fix for fried fortec ultra? please send links for help. thks
Username: Naren3001
Post Number: 18
DOES ANYONE HAVE FIX FOR COOLTEC 4000 PRO?
Username: Asam
Post Number: 20
Most of the fixes for other recievers (pantec, c00lsat, ariza, etc) should be at
www.dsscentral**.net
(Copy and remove ** after dsscentral than paste in adress bar)
look for your recievers bin file there and make sure to check forums too lots of great files there.
Username: Naren3001
Post Number: 19
when i try to get file from dss central it gives me error 404
Username: Boyce
Post Number: 257
userhelp
Can you still watch the manual or setup screen from the recevier, if not, welcome to the la la land. you need a jtag. you recevier is death/ killed.
Username: Amjad_ali
Montreal, Quebec Canada
Post Number: 18
hi Fazal the link you posted on 10th june for clone pansat 2500a had burnt my receiver.
Username: Mc_sunny
Post Number: 32
damn for real ..thats bad...thats why i don't get any files from here...
Username: Shamiadd
Post Number: 26
hey everyone, I downloaded the files last nite, and everything was workin fine, but out of no where....my screen is BLANK w/ no PICTURE:-(
i have a fortec......can someone tell me wat mite be wrong?????????
Username: Boyce
Post Number: 258
https://www.ecoustics.com/electronics/forum/home-video/239466.html
Username: Boyce
Post Number: 259
copy and paste from PT
c&p - for Vasia
try the Jtagless fix for pansats and fortecs..its at all sites..
1) Open Blacklist Stb Updater 1.3a or 1.4
2) Browse orginal bin 222. can be found from here //www.pansatusa.com //
3) Connect from PC to REC with DB9 straight cable.
4) Keep your receiver off. DON NOT TURN THE RECEIVER ON FROM THE BACK SWICH.
5) Press Send button on BLACKLIST STB UPDATER 1.3a
5) Then turn your receiver on from the back swich with in 5 secound.
6) Wait untill download complited. DON NOT TOUCH ANYTHING UNTILL YOU SEE MESSAGE (Complited)
7) DO NOT LET THE RECEIVER TO RESTART BY IT SELF.
8) After you see message complited, Swich off back button on the back of the receiver right away.
9) Wait for 10 Secound and turn your receiver on again.
10) Enjoy Your Tv Back.
Username: Babag
Hi guys,
I have pansat 2500a. I dowmloaded a file(277) with black loader. When I download, the P.C shows that it is a 100% downloaded but the reciever says that its 80% loaded. And when I scan the channel my reciever doesn't work.
So please can somebody help me with this problem.
Thank You
Baba G
Username: Babag
Hi Guys,
When I download the original Penstent software (236) the light of the reciever goes from left to right but it doesn't turn on.
When I download the file (273T) all the channels are dowmloaded but the pictures doesn't come. The Keys say wait for the picture and I waited a long time but it just keeps on searching.
Thank You,
Baba G
Username: Bungu
Hello Mr. Fazal,
do you have a fix for microyal 1200?
Thank you!
Username: Dafee99
Post Number: 116
http://www.dssmex*****.com/foros/showthread.php?t=9315
microyal 1200 since the 11th
Username: Itguy
Post Number: 14
FORTEC LIFETIME CLASSIC NA IS WORKING FINE.
Username: Majnoo666
Toronto, Ontario Canada
pls help me .i need pc to recever download file. i nee any sporting program?
Username: Babag
Hi Guys,
when I download the original Penstent software (236) the light of the receiver goes from left to right but it doesn't turn on.
When I download the file (273T) all the channels are downloaded but the pictures doesn't come. The Keys say wait for the picture and I waited a long time but it just keeps on searching.
Thank You,
Baba G
Username: Drpaulomi
Ss, Ss Usa
Post Number: 20
boyce I have PANSAT 3500 and fried pansat after upload of latest bin 352.. Now as mentioned I went on pansatusa site and clicked on 3500S i got GTM Loader and also 122 API bin... Now can i use them to set my PANSAT if not how can i get black list loader and also 222 bin
Username: Paulp73
Sam Pat..
Fortec Classic is not working fine..we are still not getting indian/asian or XXX...
did u find a new key or new bin to fix the problem...its been out since June 1st update...
thanks
Username: Boyce
Post Number: 262
userhelp
you can try the I mention above, if it still not work, then you need hardwire jtag.
copy and paste
front of reciever
near card slot
20 pin black header
1 2
3 4
5 6
7 8
9 10
11 12
13 14
15 16
17 18
19 20
rear of reciever
buy or build jtag (ebay sells them) I used a simple jtag.
I soldered my jtag to the bottom of circuit board. the pinout is as follows....
db25 connector ................pansat jtag header
pin 2 .............................pin 9
pin 3 .............................pin 11
pin 4 .............................pin 13
pin 5 .............................pin 19
pin 13 ............................pin 15
pin 18~25..........................pin 16 or a ground source
now
with jtag hooked up and 3500 turned on. start skymax up .
choose 2meg flash.....choose correct port whatever you used.
press start and allow program to make a connection.
after a connection has been established press erase
when completed erase again.
when completed choose write. when prompted select the 2 meg flash. when the write has completed.
power off.
disconnect
hook up serial cable
power on
load factory bin.
you now have a factory fresh reciever!
and you can download the flash bin from
http://www.dssrookie*com/forums/b-font-color-cd2626-3500-files-font-b/3500-jtag-files-70163.html
Username: Lklives
Post Number: 3417
userhelp...bin 352 will not kill your Genuine pansat 3500, but it could hurt a Clone 3500...Do U have power?...if so U do not need a Jtag..
Post Number: 61
Shamim !
What receiver you have ?
If PANSAT 2700A, send me email.
Username: Inayat
Richmond, BC Canada
Hi,
I am a new immigrant and installed ARIZA(400 or 500) satellite receiver to see PAK and Indian Channels.
Now i do not know how to fix my ARIZA Receiver, as i am not a technical person.Please someone who resides in lower mainland, can fix my receiver.I can come and pay for this.My e-mail address is imtiazinayatullah@hotmail.com
Please help me to get the channels.
Thanks
Username: Dishfan1
If you're looking for international programming, including Pakistan and others- DISH Network through www.AllAmericanDish.com is a great option.
Check out their web site for more details and offers.
Username: Sam_patel
hii guys is there new any fix atmega128 car if u guys know then just let me know thanks
Username: Naren3001
Post Number: 20
any news on cooltec 4000 pro?
Username: Koku99
Does anyone know why sun tv (tamil channel) is not working. I know lot of people are having the same problem. All the south indian channels are working except sun tv. I tried rescanning the channels still no luck. If you know the answer please let me know. Thanks.
Username: Drpaulomi
Ss, Ss Usa
Post Number: 21
LK thanks for your help.Boyce i appreciate your input also. Now i am bit confused..I think i have genuine 3500 Pansat ( which i bought from Ebay) i have light in my pansat and but it blinks on and off when i plug my pansat with TV..once i unplug the light is constant...Currently nothing is coming on TV when i connect my Pansat with TV..Just raindrops...Plz help what to do ..I am not sure if i need Jtag or some other fix ..Plz provide solution..
Username: Bungu
Thanks Dafee.
I will try the fix today.
Username: Inayat
Richmond, BC Canada
Hello Again,
Someone told me that no one can fix my Ariza 500 receiver for Indo-Pak Channels.
Is this correct?
Thanks for your comments
Username: Dghumman
Ontario Canada
Post Number: 36
hi guys someone please tell me wy i dont have zee tv,sony and aajtak i have rest of the international channels, i had zee tv and b4 u yesterday but i dont have it today please help
Username: Pdeep25
I have a pantec I uploaded the latest bin everything was fine, now a few channels are scrambbled one of which I watch all the time. The rest of the channels are all fine. My antena is set for 121 I entered the current key which worked 2 days ago, now the key is changed, I take off auto roll all channel goes off. I put auto roll back on everything is fine but those few indian channels do not work. in Canada for pantec receiver, on echostar --- nagravision2 are my setting can someone help me here????? my next door friend has the same hardware, and he is fine.
Puerto Rico
Post Number: 1043
Restore your pantec to defalt settings, set your receiver date, etc, set the latest keys, scan again. Lucky
Username: Pdeep25
I already did that. What is the current keycode? and what is the antena settings for indian channels if my dish is facinf south west?
Username: Boyce
Post Number: 267
userhelp
Are you sure yours is genuine 3500 Pansat.
It sounds for me your recevier is death, I believe you hook up recevier (TV out) to Television (channel 3/4), can you try hook them up with RCA (video) or Svideo etc, rain drop mean no sign to tv. My friend.
Username: Bungu
Dafee,
Which program are you using to upload? I am getting "user data unknown" error with sceditor when i try to open the file
thanks.
Username: Boyce
Post Number: 272
Fazal
A lot of IUG member at LA LA land now, where are you, they need help!!
Username: Ladym
Post Number: 7
Can someone please help me with my Ariza 400
Thnaks!
Puerto Rico
Post Number: 1075
For Ariza 400 not fix yet.
Username: Ijazsyed
Post Number: 8
hi I have pansat 3500s I am missing all indian and pakistani chanels please help me to get those back thanks
