Toshiba HD DVD & HDMI Problem
Username: Triggerfish1976
St. Pete, FL USA
I just bought the new Toshiba HD-A1 DVD Player today and hooked it up to my new Samsung HLS5686 DLP and for some unkown reason the TV is not recognizing a signal from the DVD player through the HDMI hookup. I get a signal running it through the component and my TV get a signal from my HD cable box via HDMI so I cannot figure out what the problem might be. Has anyone else had this same issue with either this TV or DVD Player?
Username: Ju1cyfru1t
Post Number: 15
I haven't done any research on your TV, but do you know if it is HDCP compliant? If your TV is not, then you will have serious problems running HD-DVD and Blue Ray players through HDMI (both players are speculated to only run HD material through HDMI as well). I will look around and let you know what I can find.
This may not be the case at all, but it's a place to start. If anyone has more knowledge, please feel free to correct me.
JU1CYFRU1T
Username: Kano
BC Canada
Post Number: 956
Different versions of HDMI between player and TV?
St. Pete, FL USA
There is no mention of HDCP compiancy in the entire manual.
St. Pete, FL USA
There is no mention of HDCP Compliancy in the entire manual. If this was the issue why would I get a signal from my HD Cable box through the HDMI interface?
St. Pete, FL USA
I called Toshiba and Samsung and neither one can determine the problem. Toshiba's tech support was basically worthless. I spoke to three different people and I could tell they were just given a sheet with basic Q&A responses. I did find out that the DVD player has a version 1.1 HDMI and the TV has a version 1.2 HDMI but I read that HDMI is suppose to be backwards compatible.
Username: Dblake15
Here is the info you are looking for.
http://reviews.cnet.com/4531-10921_7-6526656.html
Username: Mikemv1977
Saskatoon, Saskatchewan Canada
Post Number: 13
Hard to say what the problem could be, but this might give u a mild idea of where u can try and trouble shoot: http://www.hometheatermag.com/discplayers/0506toshiba/
or this one:
http://www.soundandvisionmag.com/searcher.asp?section_id=1&article_id=0
Its usually a good idea to read and know b4 hand what ur getting urself into b4 u find urself stuck. hope it helps ya.
