Take Off Doors in 2000 Mitubishi Eclipse GT
Username: Robman0079
Post Number: 76
Hi i posted this in the speaker section, but the section is broken???? Anyways, does anyone know how to get the door cover off so i can replace the speakers. I can get almost all of it off until i get to the corner near the mirror and it just wont pop off??? Can anyone help me, pictures, website, anything that will show me how to get this door off???? THANKS
Username: Justblaze
St.Louis, MO USA
more likely then not your going to have to remove the entire door panel to get the speaker out. most cars nowdays seem to make it impossibel to get the speaker out just through the speaker gaurd. you may want to try registering on cardomain and ask someone who has speakers in the 'clipse. good luck
Post Number: 86
i figured it out there was a bolt underneath the door handle so i could get it off thanks neways
no more posts on this thread needed
