Quick question...
Username: Okstate132
Tulsa, OK Usa
Post Number: 12
I have just purchased 2 10" assassin subs and i was wanting to know what kinda box i should put it in?
Tulsa, OK Usa
Post Number: 13
Is there any sorda box that would get me a better quality of sound?
Username: Ctmike
Ct.
Post Number: 837
sealed will be if you want tighter bass, better sq, ported for more spl but you lose a little sq.
Tulsa, OK Usa
Post Number: 14
so you would go with sealed?
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 985
i would go ported at 30hz ull loose a lil sound quality....but im sure u will like the result....
Tulsa, OK Usa
Post Number: 15
would 38hz be to much... or do u think it would be alright without effecting the sound quality too much?
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2618
38Hz be WAY too high.
go with 30-32Hz
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 253
38 would sound horrible. i would say no more than 35. I am doing my 2 15" arsenals at 35 tomorrow!
Tulsa, OK Usa
Post Number: 16
ok, thx, one more question... Are 2 10" subs, better than one 12"?
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 242
two tens have more surface area. so depending on which way you mean better, for the most part almost always two tens will be better than one twelve atleast when comparing the same subs.
