New member Username: Jurkey77
Post Number: 1 Registered: Jun-06
Posted on Ok so im hooking up a amp+sub combo The amp is an alpine v-12 monaural mrv-100m powering an alpine type s 12" in a ported box the setting on the amp are what i need figured out the setting options are as follows: a PHASE switch with the options of 0 or 180 A lp filter dial ranging from 50 to 200 Hz which i looked up and set to 80 a bass eq switch with the options of on or off and a dial from 0 dB to +12 dB and a gain dial from min to max what should i set what to? Thanks in advance!! |
