Bronze Member Username: TruthLansing, Mi US Post Number: 22 Registered: Jun-06 | I need 2, names some good ones. |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 512 Registered: Feb-06 | B's autotek 2000d($400) orion 2500d kicker 2500 |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 2381 Registered: Feb-05 | US Amps makes one that large i think. might wanna ask Alteraudio. Orion and Kicker amps SPD mentioned above are nice. i've never messed with Autotek though. |
Silver Member Username: James_gTN Post Number: 503 Registered: Jul-05 | Doesn't Autotek = Hifonics???? If so, there are much better deals on eBay. Why buy an Autotek "2000w" amp that puts out maybe 1600w when you can get the Orion or Kicker 2500w for a little more and actually get more than the rated 2500w?? |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 887 Registered: Mar-04 | having the same parent ownership doesn't make them the same products. Is a Pontiac GTO the same as a Chevy Aveo?? They're both GM products, right? |
Gold Member Username: IlluminatorUSA Post Number: 3158 Registered: Apr-05 | ^ Good point, just because Ford has ownership over Aston Martin, doesn't mean an Aston Martin isn't any worse. |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 514 Registered: Feb-06 | https://www.ecoustics.com/electronics/forum/car-audio/239842.html |
Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 265 Registered: Mar-06 | Hifonics and Autotek are owned by Maxxonics and Maxxonics owns MB Quart..... |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 743 Registered: Dec-05 | autotek is nice and underrated, mb quart is good rated and hifonics puts 70% stated |
