Question abou EPG for BEV
Username: Tariqic
Post Number: 42
Is it possible to get more than 2 hours of EPG for my C5K receiver for BEV? If yes, how can I do that. Thanx in advance
Username: Ikaleem
Post Number: 65
Tune to channel 1212 and then turn the EPG on...keep it on EPG for a while and it will populate the epg upto two days or more
Username: Nickb
New York, New York USA
Post Number: 50
Hey...
Is it possible to also load the epg from that same channel using Fortec LU.
I looked in my channel list but I dont find a 1212.
Thanks for your help!
Username: Tariqic
Post Number: 43
Thanx Wizard. Much appreciated.
Username: Racer43
Hey Wizard
Works great for Bev is there a similar deal with DN
My EPG on DN only gets the hour.
Thx
Username: Karla
Post Number: 40
What's EPG?
Username: Lklives
Post Number: 3469
Program Guide
Username: Nickb
Post Number: 51
Hey...
I\\'m not finding a 1212 in my channel list.
Can someone tell me the station id or details?
Thanksss!
Username: Nickb
Post Number: 52
Hi..
Just wanted to know if there is a way to load that programming guide data if I am using FTA?
Is it the same channel 1212 on BV?
Or what do I do exactly?
Thankss!~
Username: Nickb
Post Number: 53
Sorrry I don\\'t mean to be a pest..but can someone tell me how to do that channel 1212 on BV to load the epg...that Wizard talked about a few posts above!!
Pleaseeeeeee..thanks!
