OT-strong glue
Los Angeles, CA USA
Post Number: 4106
anyone know of any glue that will bond wood and plastic together really strong? i want to glue a mdf ring on the door panel where the components spkrs are. then i will screw the speakers on to the wood.
i need a glue that is real tough and won't come off after time.
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 176
HMMM. GORRILA GLUE MAYBE? But its not cheap
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2607
gorrila glue will work...ITS STRONG AS FU CK lol.
and yea it IS expensive for the little amount u get.
Los Angeles, CA USA
Post Number: 4109
thanks guys. gorilla glue it is then. i don't need that much anyways.
btw how much is really expensive?
Username: 54danny54
Post Number: 2611
mine was like 8-10 bux for like 10 bux for the small size...which has an ounce or 2
Post Number: 178
Cant remember the exact price, but I think their largest size bottle will run 20-25 bucks(at wal-mart even)...but hey.. it does hold
