Box building very quick question
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 719
Whats a good amount of time for the glue to set before I should test 'er out?
thanks
Username: Shman
Grandville, Michigan United States
Post Number: 256
i'd think 45min to an hour would be fine depending on the glue....
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 891
liquid nails is about 24 hours for OPTIMUM reliability
Username: Shman
Post Number: 257
but if you SCREW it together and liquid nails the inside i would think you should be fine in the time it takes to hook it to your amp....
Username: Lexuscoop
Post Number: 892
yup
Post Number: 720
K well I used some tourquey glue stuff, needed a caulking gun to use it, its what carpenters use it seals like cement. Its like bull dog 3500 or somthing or other.. and I used a bunch of deck screws. Yeah the box was glued yesterday night and I should be doing some touch ups so hopefully it will be in today or tomorrow morn!
thanks alot
Username: Lexuscoop
Post Number: 893
today it should be fine like in a few hours or so
