I am currently using FTLink34.exe loader to download digiwave 7000 files, on to my Multistar max 2500 reciever, as suggested by mayorsatlite*com, but I kept having communication and hardware problems, what is it that I am doing wrong, do you have any suggestion for me thanks in advance
Hey Lk I've tried searching for Latest GTLoader for BL New Bin but cant seem to find any info, Could you direct me to where i could find the newest Loader?
LK thanks for the insight, I did used Blacklist updater along wit bin 277t, I had an error writing message, I beleive this is digiwave clone, is likely to use digiwave 7000 file, for this Multistar Max 2500, but what loader would I used for this since FTLink 34 is not reconizing the files, any suggestions.
Barbara: Give to us more information, please. About: but I kept having communication and hardware problems?????????????????????? Which type of problems do you have?
Everyone today is on a loader kick!...the loader is not that important!...if its a pansat bin,use any Pansat loader!...it that doesn't work then use the loader for whatever receiver type U have...main thing is that the receiver and computer communicate...that means the CORRECT cable and SERIAL port!...995 of the problems here are WRONG cable or WRONG comport...which has NOTHING to do with the loader!...and the reason for WRONG comport and cable is cause people here do NOT read anything about their own receivers!
Now quit all this loader crap...its irrelevant most of the time!
OK so its not a loader i need ...but i still get Model name not Correct...i have tried Pansat 2500a no good..i tried key:global not good either...Now is it that i need a Space between the wood Key_:_Global _= blank space
with that message . I think your typing is not correct . When you type model name for ... , EX. "Pansat2500A" I think should have a SPACE between Pansat and 2500A . hope this help
kevn: Download bl loader or the last gtloader upload-1133535632-Pansat 2700A GTRom loader v3.35 With these loader you can not select any model, only a bin file, and remember for 2500 use straight cable, let me know.
