Pansat 2700-N2
Username: One2env
Hey guys is a Pansat 2700 N2 clone safe bin? if so can some one please tell me where it is.
Thanx in advance
Username: Lklives
Post Number: 3327
that is a receiver!....LMAO
Username: One2env
srry what i meant was is there a clone safe bin for that reciever?
Username: Lklives
Post Number: 3333
yes here..272v1 bin
[link removed]
Username: One2env
Thanx a lot LK
by any chance do you know what loader i should use,
BL loader or GTRom Loader?
Thanx a lot
Username: One2env
Thanx a lot LK
Thanx a lot
Username: Lklives
Post Number: 3355
Loader doesn't matter...whatever one works for U..loaders are like cars...some people, bins, receivers, prefer certain ones..but they all do the same thing!...and there is NO telling which bins or reciver prefers which...I prefer BL updater V 1.4 myself!
Username: Slimatic84
Sir,: LK
I need your help!
I am having problem with my ANTENNA SET UP.
2 - DISH
3 - LNB
SATTILITE: 61.5, 119 & 110
I am only getting 110 & 119 on my Pansat 2700a.
can you send me SATTILITE SETTING on all three of the above if you are running the same set up like mine or your advice.
*** ALL DISH IS POINTED CORRECT & CHANNEL LISTING 119, 110 & 61.5 WAS DONE ****;
BECAYSE MY FORTECH NA BOX IS WORKING PERFECT ***
Username: Lklives
Post Number: 3421
all settings are the same...except disque switch ports
119...1
110...2
61.5..3
Maybe the 61.5 has bad cable, poor connections, bad port in disque switch, bad LNB, misaligned LNB..or old channel list where the 61.5 channels have moved to another transponder or satellite..
Username: Lada
Montreal, QC Canada
Post Number: 40
LK. Can I use Loader BL 1.4 for Digiwaiv 7000?
Thanks.
LK,
thank you very very much for that info, however where can I find a recent CHANNEL LISTING for 119, 110 & 61.5 as you see I am new but I am a very quick learner. I thin the one I am running at home was since in 02/06.
Username: The_wank_artist
Post Number: 898
L'sean,
Go to dsscentral*net to get a new channel list.
You'll still have to edit it as the last posted was from April or May, and there have been changes since. There is a newer channel list there too but when I tried downloading it the other day it failed to download.
You can use either of these sites to help you with the edits.
http://ekb.dbstalk.com/dishlist.htm
http://www.lyngsat*com/
where * replace with .
Username: Lklives
Post Number: 3422
Many Channels lists at www.future-fta.info or www.al7bar.t*k ...or scan the satellites instead..
Username: Moyo18
i have a problem with the pansat 2700-n2 when i downloaded the bin for pansat 2700 it worked great but then the box didnt work, there is not power at all. what is the problem?.
Username: Lklives
Post Number: 3430
U used the 272 bin and killed your CLONE 2700 receiver...U now must Jtag it...U should have used the 2700 CLONE safe bin 272v1...shame on U..
Username: Moyo18
what "Jtag" means??
Username: Moyo18
i have the bin for pansat 2700 n2 but when im trying to donwload the bin to the receiver i cant do that, the problem still with the power so what can i do? i have to buy a new one or can i repair it?
Username: One2env
Post Number: 10
Dude u have to jtag your reciever first then load the bin there are few things you can reat about jtaging at dsstester.c*om, basically jataging puts ur reciever in clean "fresh" state. Then you have too put in the bin (software) in too the reciever for it to function.
Username: Lilydavie
PLEASE HELP I'M NEW AND DUMMIE.
I HAVE PANSAT 2700A 1 DISH TO 110 OTHER DISH TO 119.
I RUN THE BLIND SCAN FIRST WITH DISH 110, AFTER THAT RUN SCAN WITH DISH 119.
AFTER THAT I INSTALL THE SWITCH AND PUT TOGETHER THE TWO SIGNALS TO THE RECEIVER.
NOW I HAVE A BUNCH OF CHANNELS, ALL IN ANY ORDER, MANNY DUPLICATED. I WANT TO KNOW HOW CAN I PUT ALL IN THE ORDER THAT YOU FIND THEM IN THE NETWORK, WITH THE SAME CHANNEL #.
I HAVE THE PANSAT2700A CHANNEL EDITOR 1.8.7.1261 BUT I DON'T KNOW HOW USE IT.
THANKS IN ADVANCE
CARLOS
Username: Evadelparaiso
Puerto Rico
Post Number: 1037
go to dss**tester.com download the guide to channel editor. In your remote go to SAT, Echostar package, hit twice. You can view the list as DN have. Go to edit channel and you can edit, delete etc the channel list. You can too Delete all channels Go to menu, Installation, Satellite scan, Select all satellite (3),(you will see in red the button when you select the satellite to scan) and hit ok to scan all satellite at the same time. If you select this option you dont have duplicate channels. But master channel edit its a great program.
Username: Peortiz
Im trying to wrtie the bin for the first time on my receiver but it fails every time.
I have a Pansat 2700A and Im using a RS 232 cable that says null modem.
Im using the GTRom Loader v.3.38 with the Bin File: X_87BL_060609_272_api_2.
Im new at this so please Help!
Thank YOU ALL!
Puerto Rico
Post Number: 1045
Pedro: Change the bin to: Pansat-Clone 2700 272v1 if you still have the same problem change to straight cable. Lucky
dss**tester.com Pansat area
Username: Boyce
Post Number: 273
Pansat 2700-N2 jtag kit
Here's a kit consisting of how to make a jtag cable with pictures, the software, & a "how to" use the software with screenshots
If making your own cable and you have a ten pin header, substitute the following schematic to the 20 pin how to:
pansat 10 pin layout:
2 4 6 8 10
1 3 5 7 9
hs1
10 pin cable schematic:
DB25 pin2------100 ohm resistor ---> Pin 4
DB25 pin3------100 ohm resistor ---> Pin 3
DB25 pin4------100 ohm resistor ---> Pin 1
DB25 pin5------100 ohm resistor --> Pin 8
DB25 pin13----100 ohm resistor----> Pin 6
DB25 pin18 to 25----------->GND Pin 9
download software and file below.
http://www.dssrookie.com/forums/b-font-color-cd2626-general-utilities-font-b/pan sat-2700-n2-jtag-kit-76919.html#post501271
