Bronze Member Username: RadiocodesPost Number: 28 Registered: May-06 | Simply click here : http://www.radio-code.co.uk/premium_rover_radio_codes.php |
Gold Member Username: IlluminatorUSA Post Number: 3145 Registered: Apr-05 | Whoa, they don't even have a display? Anyway, read the board policy please: If you participate in any Forum within an eCoustics.com site, you MUST NOT: -advertise or sell to, or solicit others; -use the Forum for commercial purposes of any kind; Thanks. |
Bronze Member Username: RadiocodesPost Number: 29 Registered: May-06 | I do apologise for the advertising however Rover codes are hard to obtain in the UK now. And Rover radios do have a display !!! Either in the Dash or On the Radio... |
New member Username: BeachbumPost Number: 3 Registered: May-06 | Okay, I now have the remote control working but I have no memory. I have an solid orange and a solid blue wire on the car side and a blue/white wire that are not connected anywhere, are any of these the memory? |
Gold Member Username: TjmutlowPost Number: 2346 Registered: Sep-05 | sounds like there is a constant wire problem, put a test light on those wires and see if any of them are powered with car off.... |
