BEV
Username: Monst
Hey guys what direction do I need to point my dish to get BEV from Texas zip 75052.
Username: Monst
I guess no help there.
Username: Lklives
Post Number: 3484
In another thread U started here , U stated U didn't need to read manuals at a recommended site (dsstester)....well don't come here and POST questions like this...Dsstester HAS manuals and files that answer your exact question...
there are NO files , Guides, manuals here..go away and read...Do NOT POST here!
NOBODY answer this LAZY SOB!!!!!
Username: Monst
sorry for late reply. Now listen you LK Lazy SOB just because you are a gold member does not give you right to call somebody names. I think your parents did not teach you manners and how to talk with respect. From now on don't open my threads I don't need your help anyway because you are an A.. hole.
Username: Ultimatefreaker
Post Number: 13
you point the dish north toward canada cause its a canadian provider right LK.lol!
Post Number: 14
Username: Boyce
Post Number: 279
monster
try this link http://www.kusat.com/go.php?path=/install/look.php
Username: Boyce
Post Number: 280
dankauff
what so funny, BTW it still point to south.
Username: Banzai
Post Number: 41
There are 4 SAT for BEV (Nimiq 1-4), but the 1 & 2 use the most (Nimiq 1 is most english & French Canada channels, Nimiq 2 is HD channels and Internation channels).
Please check this http://www.lyngsat.***com/tracker/america.html for the position of Nimiqs SAT.
Hope this will help and don't forget to remove *** from the URL.
Username: The_wank_artist
Post Number: 960
thien,
what are the other two BEV?
82, 91 and which others?
Username: Boyce
Post Number: 290
4 bev ????
Username: Banzai
Post Number: 42
Tyler Durden & Boyce
C/P from "http://satellitetv.digitalinsurrection.***com/bell_expressvu.php"
In 2004, Bell Expressvu acquired use of an older Directv DBS class satellite, which was re-named Nimiq 3 and located it at the 91° orbital location, to operate with Nimiq 1. This would allow Expressvu to strengthen its reception in Canada by increasing the power on the satellite by removing 8 active transponders on Nimiq 1 and using Nimiq 3 to transmit these instead. This re-allocation had a negative effect for some Canadians living in the USA, as it caused a loss of signal in many southern US states, that had previously enjoyed excellent reception. Although neither Expressvu nor Star Choice are authorized to broadcast outside of Canada, indeed a flourishing U.S. grey market exists with some Canadians living in the USA and U.S. residents looking for Canadian programming would subscribe to the services. Some of these U.S. gray market subscribers needed to upgrade their dishes to larger ones. Others, especially in Florida and southern states found they needed to switch to Star Choice to continue receiving Canadian programming.
C/P from "http://www.space.eads.***net/press-center/press-releases/eads-astrium-awarded-nimiq-4-satellite-by-te lesat"
Nimiq 4 will continue to enhance digital television services in Canada. It will feature 32 active high-power transponders in Ku-band and 8 in Ka-band. The multi-spot Ka-band payload will provide coverage of the most densely populated regions of Canada.
and check the location of those 4SAT "http://www.lyngsat.***com/tracker/america.html".
P.S.: remove the *** in the URL
Post Number: 962
http://www.space.eads.net/press-center/press-releases/eads-astrium-awarded-nimiq -4-satellite-by-te lesat
Our apologies...
The item you requested does not exist on this server or cannot be served.
Please double check the web address or use the search function on this page to find what you are looking for.
If you know you have the correct web address but are encountering an error, please send a mail to the administrator of this site.
Username: Monst
Post Number: 9
Thank you guys I really appreciate all the help I got from you guys. I would definitely try everything on this weekend to get BEV.
Username: Banzai
Post Number: 43
hey Tyler
the URL broken due to the limite of screen length. Check the last wrod of the URL. it's "telesat" but not "te lesat", that's why you got the error.
http://www.space.eads.net/press-center/press-releases/eads-astrium-awarded-nimiq -4-satellite-by-telesat
