Digiwave Fix Fully open
Username: Hshakarchi
Post Number: 17
Finally the fix is out
go to (dssevolution*com)
Register and download the bin for your receiver,
they are for Digiwave 5900, 7000 and 7200
It is running now.
Load the fix put the keys manually and ENJOY
Thanks to the coders!
Username: Evadelparaiso
Puerto Rico
Post Number: 954
Im happy for all Digiwave users.
Username: Bladam
Post Number: 47
I am currently using FTLink34.exe loader to download digiwave 7000 files, on to my Multistar max 2500 reciever, as suggested by mayorsatlite*com, but I kept having communication and hardware problems, what is it that I am doing wrong, do you have any suggestion for me thanks in advance
Username: Jdq
Post Number: 123
Barbara are you using null modem cable.
Username: Bladam
Post Number: 51
Thanks JDG, I will take a look to make sure it is the correct cable
Username: Jdq
Post Number: 127
Barb I had trouble with com 2 had to use com 1 at back of computer
Username: Alibaba_can
Post Number: 15
Hi
I need the loader for the digiwave 7000
Please help
Username: Jdq
Post Number: 128
Loader is FTLINKS 3.4 TRY dss ev@lution
Post Number: 17
Does this work on digiwave clone (technosat 1010+)
I down load to my receiver but and getting scrambled channels
Username: Marco1979
Post Number: 13
it should work on clones - it works on kusat 2600 which is a clone to Digiwave 7000.
Post Number: 18
ali baba
I think maybe u did not put keys
after downloading the bin file,
put the dishnet keys or bev keys whichever ur using
Username: 1cipher
newb question - i used a 9 point m-f serial, but am having difficulties - is this different than a 'null modem cable'?
Username: Ftp
Digiwave DG7000 fix from dssevolution*com works for me!
Still testing, but appears to have autoroll, working EPG, BEV, all outputs...
Good job! :-)
Lost my channel lineup when I flashed, so you should have it backed up, and don't trust FTLink button that says you can just flash the bin and leave the factory_data.txt intact.
Username: Momenali
Post Number: 69
Digiwave is still a Cheap, non-reliable peace of crap..
Username: Jdq
Post Number: 132
Support is unreliable but the cheap piece of crap works great,picture is great and easy to use.But thanks for asking
Username: Hockey2006
what the new bin
