Why won't my ps2500a flash?
Username: Banej
Post Number: 12
I tried everything to flash my cloned ps2500a. I just got another cable from radioshack RS-232C Female DB9 to Female. I also tried different loaders BU 1.3 and 1.4. every time same message "WRITE FAILED (ER 1)" I also tried using COM1 through COM4. Nothing works. I tried flashing it on two different computers and still nothing. PLEASE HELP!!!
Username: Evadelparaiso
Puerto Rico
Post Number: 1052
which bin are you running?
Puerto Rico
Post Number: 1054
go to dss**tester.com search loader, download the Gtroam loade rupload-1133535632-Pansat 2700A GTRom loader v3.35, run Pansat Files » Pansat.2500a.0608-BL and the bin:
This the official Blacklist release for the Pansat 2500a fixing June 2nd PPV/XXX hashing.
Date: 09/06/2006 - View Full Info - Downloads: 2921 - Download Pansat.2500a.0608-BL (533.32KB) IF you still have the same problem, do you need a different cable if you are using straight try with null. Lucky
