Pansat 2500a Fried!!!!!
Username: Gunaa
Post Number: 40
Hi guys!& LK!!!
Any posible to fix the pansat 2500a without J-TAG...?
Username: Evadelparaiso
Puerto Rico
Post Number: 945
Your pansat 2500 turn on?
Username: Gunaa
Post Number: 41
NO!! LIGHT NO TIME NOTHING.
Puerto Rico
Post Number: 949
Do you need jtag.
Username: Gunaa
Post Number: 42
Really!!!!
Username: Gunaa
Post Number: 43
Eva Diaz!
Any link out there to do the jtag step by step?
Username: Vasia22
Post Number: 19
Hi ppl, Anyone has JTAGED Forsat 2500 Ultra before?? I've read alot of info about it, and tryed different ways of doing it, but still no luck. Used Skymax( says Init JTAG IDCODE : FFFFFFF
Fail DCU, Plesae Restart or Reset CPU Box), than wall.exe with Jkeys ( cannot detect the device)
i checked my jtag connectons 100X.I used Db25 cable male to male it has only 11 wires) ANY Ideas??
Username: Gunaa
Post Number: 44
Any 1 know whare can i get Pansat Factory Loader (PFL)?
Puerto Rico
Post Number: 956
go to dss**tester.com download jtag manual for ultra. Lucky
Puerto Rico
Post Number: 957
http://www.dss***tester.com/files.php?cat=14&cmd=all&sort=&order=&page=7 remove ***
Puerto Rico
Post Number: 958
Gunaa go to dss**tester.com search jtag and download the manualfor your receiver. Lucky
Username: Mty
Mexico
Post Number: 135
hello Eva would you please help me, I was out of this for one month more or less my computer broke and I don't know what bin are using for pansat 2500 original, I have been reading but a lot of people say their pansat burn.
thanks a lot
Username: Lklives
Post Number: 3357
277 bin released 9 June for GENUINE Pansat 2500....277T for 2500 clones,released 10 June
here's ALL the Pansat bins, loaders, Jtag manuals, input key Guide, etc...
[link removed]
Username: Yunairy
LK any new keys for pansat 3500? please
Username: Lklives
Post Number: 3360
same old keys..no changes!...old keys are good!
Username: Rikarddo
Post Number: 34
just go to dss*community.com and u need to suscribe for free but its worth it.seach in the forums.they offer a lot of help on jtag stuff or search in the picture files and u'll get it fast i tried it already so good luck.
Username: Yunairy
thank you
Username: Vasia22
Post Number: 21
Guys plz need help! Tryed Almost evrythink! Forsat 2500 Ultra died after wrong bin ....
I tryed jtagless fixes , nothing worked ....
Build jtag cable , and used skymax wall jkey
still dead!
anyone jtaged this receiver ??! ANY ideas?
Username: Lklives
Post Number: 3364
Thousands have jtagged it with no problems...there are hundreds of Jtag manuals at all the DSS sites...U must follow them EXACTLY!..U will Not get it Jtagged here!...U can bring it to an electronics repair shop and for about $60 they might Jtag it for U..
If U can't put the correct bin in an Fortec Ultra (especially when there is ONLY 1 working bin)...then U probably do not have the capability to do a Jtag..
Username: Lklives
Post Number: 3365
Its the same Jtag as a Fortec Ultra or a Pansat 2500!...and bin 277T is what U need after using bin 224!
Username: Vasia22
Post Number: 25
Maybe they work with the same bin, but have different mainboards, even jtag pins different i look at all of them. i loaded the bin long time ago, it worked for 10 min and than died
Username: Lklives
Post Number: 3385
it might look different but its the same!...a Jtag for a Fortec ultra and a pansat and most all receivers are the exact same...or if not, then they cannot be Jtagged, like a coo*lsat, and must be shot and put down like a horse!...U cannot Jtag those , and they go in the garbage where they came from any ways! ( I do not mean coo*lsats belong in garbage) but if it cannot be Jtagged using the Pansat method, then there is NO Jtag available and U must just throw away the receiver!,...its useless then!
Username: Lklives
Post Number: 3387
Jtag info and pics...
[link removed]
Username: Bthitman
Post Number: 14
LK what is Jtag? I have a Genuine Pansat 2500.
Username: Lklives
Post Number: 3390
Jtag returns the receivers brain back to the factory settings ,before it got fried using a wrong bin..thats put in laymans terms..Jtag involves soldeing pins, making cables, usinf various programs and flashing original bins...its a complicated process for a newbie..
Username: Vasia22
Post Number: 26
LK there are connections for jtag its even written there tck trst ..... so u cant go wrong, but still doesnt work!!!! and yeah in electronik store that u talking about , they jtag it .. i guess its not garbage yet!!! Unless U dont know what might be wrong?!
Username: Bthitman
Post Number: 15
Thanks for the info LK.I am a newbie to this so I need a bit of help.
Username: Steph_raven
Les Cedres, Quebec Canada
anybody try the new bin for the pansat 2700 clone from dsstester....try it at your own risk cuz it works for a bit the you get a message that tells you you have a clone and when you turn it off....it never comes back on...now that's not funny!!!
Username: Vasia22
Post Number: 27
LK if Forsat 2500 Ultra cannot be jtaged , what whould u recomend as a new receiver?
Username: Lklives
Post Number: 3398
Viewsat Extreme...Co*olsat 6000
Username: Mty
Mexico
Post Number: 136
HELLO LK:
THANKS A LOT
Username: Mares
I upload the new bin to the 2500a
how I update the channel list ??
please help
Username: Mty
Mexico
Post Number: 137
do blind scand Mario
Puerto Rico
Post Number: 1013
Welcome again Patricia.
Username: Mty
Mexico
Post Number: 138
thanks Eva, I have my computer again
Username: Coollbreezz
Little rcok, Ar
i download the bin to fix night rider light..now my my pansat 2500a keep cutting off and on....please help...
Puerto Rico
Post Number: 1059
run the bin again. Disconnect receiver, when ready to download bin, connect and at the first light on run the bin. First turn off back button and turn on again.
