Two amp for two Type R DVC 4 OHM.
Username: Aman2005
Post Number: 166
I need two amps for powering my two 10" Type R DVC. I will look around for the amp. I want to know that is there any harm on electric system if I hook two amps rather one??
Say If I need 1000 wrms, will two having 500 500 WRMS consume more current than a one 1000 amp??
Username: Tjmutlow
Post Number: 2344
get like a kicker 1200.1 or a jbl 1200.1
Username: Aman2005
Post Number: 167
Sir,
I said that I will look for an amp. I just want to know about hooking two amps will create some bad effects on car ELEC SYS or not?
Username: Tjmutlow
Post Number: 2352
well sir, common sense, the more you hook up the more strain it is going to have on your alt.....
Username: Aman2005
Post Number: 169
But i think the amperes depend upon the RMS. Please clarify
