Username: Alexv305 Tavernier,
FL
Post Number: 228 Registered: Oct-05
Wednesday, June 14, 2006 - 23:22 GMT Does anyone know a good way to make terminals for an enclosure? I dont want to use those plastic terminals that I would have to cut a hole out for. Any ideas would be appreciated..
Username: Bulldogsm2008 Iowa City,
Iowa
Post Number: 195 Registered: Mar-05
Wednesday, June 14, 2006 - 23:27 GMT just drill a small hole just big enough for the wires to fit thru then silicone it shut.
Username: Theelfkeeper Stockbridge,
GA
Post Number: 2368 Registered: Feb-05
Wednesday, June 14, 2006 - 23:28 GMT just drill a hole the size of the wire and fill in any cracks with silicon. easy and cheap. thats the way i always do it. i've seen someone run a bolt through the box and attach the speaker wire on either side.
Username: 54danny54 Betsy layne,
Kentucky..GO...
USA duh
Post Number: 2576 Registered: Nov-04
Wednesday, June 14, 2006 - 23:29 GMT long screws like a couple inches long...with sum wingnuts
FL
Post Number: 229 Registered: Oct-05
Wednesday, June 14, 2006 - 23:35 GMT i tried that and the nuts keep coming loose..
FL
Post Number: 230 Registered: Oct-05
Username: Gcs7th NY
Post Number: 20 Registered: Jun-04
Thursday, June 15, 2006 - 04:43 GMT On my box i used the plastic cups but i reinforced it with another peice of wood behind it with caulk and screws so i didn't compromise any of the integrity of the box. And thne i siliconed the terminal cup in so it would be near impossible to get a leak in that.
