Does anybody have the new keys for pansat2700A and Digiwave 7000?
Username: Chicas
London, Ontario Canada
Post Number: 10
I put the new keys eva said E8....and 71...but don't work. Any idea anybody?
Username: Evadelparaiso
Puerto Rico
Post Number: 996
If you have pansat 2700 you can see a big listed channels, without premium, ppv or internationals. If you cant see any channels do you have another problem to run a new bin.
Username: Chicas
Post Number: 11
A couple of days ago I still had a few channel about 15 channels, now there are all back. This was the old bin. I have never run a new bin before. I have just done it manually. Can you help eva.
Username: Lklives
Post Number: 3441
Read the manuals and upload the NEW bins!...nobody can do it for U!!!!!!!!LAZY!
Puerto Rico
Post Number: 1001
Of course
c/p
For ALL Pansats....
Things you will need!
1.A computer with a com port!
2.The right cable to connect to your computer to your receiver!
3.GTROM LOADERv3.34 or newer!..or another loader like BL 1.4
4.New pansat 2700bin!..or another Pansat bin
5.LNB setup and the right switch!
6.Sat Signal at 70 percent or higher!
1.Power down receiver and computer!
2.Connect receiver to computer and power both of them up!
3.Start up gtrom loader v3.34 or newest version and select the new bin file you wish to upload then click download wait until it is finished it will go to a 100 percent but it is not finish until it displays burn complete or finished!
4.Turn off power to receiver and computer and remove the cable from the receiver!
5.Install cable from the lnb and the cable from the tv and the plug it up and power up the receiver!
6.Using your remote hit menu and the parent control then ok in second pin enter 0000 and then ok!
7.Then set default key..EMU-ON then ok!
8.Go to Nagavision2 then ok and check 00 and 01 keys. Put in new keys if need then hit ok to save!
9.Now installation then ok antenna setup then ok make sure you have 110 and 119 and check to make sure the switch is set right for both on the diseqc setting! If 110 is on 1 and 119 is on 2, set diseqc the same way!
10.Now go to blind scan and hit ok!
11.When finished exit menu and watch tv!
To download the new bin go to dss**tester.com Pansat downloads area Download the 272v1 bin, go to search write Loader, download bl or gtrom loader, unzipped both files, and follow the instruction above. Lucky
Username: Donnie1973
Post Number: 24
I dont think u have to power down the pc at any time. At least not for the 2700a. Not sure bout the clones though.
Username: Chicas
Post Number: 12
I GOT NO MANUAL WHEN I BOUGHT IT, AND NO CABLE TO CONNECT TO THE RECEIVER AND I PAY $275 FOR IT. DOES ANYBODY KNOW IF FUTURESHOP SELL THEM?
Username: Chicas
Post Number: 13
Gracias Eva aunque no tengo las cosas que necesito para hareilar mi recividor. No era simple como lo pensaba que iva ser. Yo pense que solo necesitaba las claves pare que funcionara.
Puerto Rico
Post Number: 1038
Antonio: All in this life, is about read, learn and want to do. If you read a little, you will see its not difficult process. Go for it!
