FTA - if you do not have DishNet 110
Username: Proxmat
I've been using this forum for info for sometime so here is a small contribution from me for those that may find it helpfull.
If for any reason your dish IS aimed at 119 and NOT at 110:
with the last BIN file there is requirement (see "text file" that comes with BIN) that you should have your reflector (dish antenae) aimed at the bird located at 110 degrees. If you do not the EPG may not download or take up to 8 hours to do so. This is a fact. However do not be dicouraged. Even with 119 ONLY available (if that is your case) the new BIN (BL 272) will work. You should not have to enter keys manualy eather.
When you program your Pansat 2700 A and turn it back on you WILL NOT get as the 1st screen the "downloading EPG" and "OK" this option. What you will get is directly "waiting for picture" screen. Here is the trick - BE PATIENT here!! It will load really slowly (may take more then an hour) but it will load. All that is available on that bird will slowly come in.
Also as for the signal strength it does help if you have 70% as some other members mentioned. But you can get away with as little as 45%.
Username: Wakenbake
Post Number: 196
in other words:
pull head out of a##
Username: Proxmat
Right...
