Username: Bestmankind Los Angeles,
CA
Post Number: 4106 Registered: Oct-05
Friday, June 16, 2006 - 00:10 GMT anyone know of any glue that will bond wood and plastic together really strong? i want to glue a mdf ring on the door panel where the components spkrs are. then i will screw the speakers on to the wood. i need a glue that is real tough and won't come off after time.
Username: Wolfman1966 WEST MONROE ,
LOUISIANA
Post Number: 176 Registered: Jan-06
Friday, June 16, 2006 - 00:17 GMT HMMM. GORRILA GLUE MAYBE? But its not cheap
Username: 54danny54 Betsy layne,
Kentucky..GO...
USA duh
Post Number: 2607 Registered: Nov-04
Friday, June 16, 2006 - 00:19 GMT gorrila glue will work...ITS STRONG AS FU CK lol. and yea it IS expensive for the little amount u get.
CA
Post Number: 4109 Registered: Oct-05
Friday, June 16, 2006 - 00:21 GMT thanks guys. gorilla glue it is then. i don't need that much anyways. btw how much is really expensive?
Kentucky..GO...
USA duh
Post Number: 2611 Registered: Nov-04
Friday, June 16, 2006 - 00:24 GMT mine was like 8-10 bux for like 10 bux for the small size...which has an ounce or 2
LOUISIANA
Post Number: 178 Registered: Jan-06
Friday, June 16, 2006 - 00:35 GMT Cant remember the exact price, but I think their largest size bottle will run 20-25 bucks(at wal-mart even)...but hey.. it does hold
